Hi, I have this dryer run 3 times before its dry one load. is there anything i can do. Thanks Jake
The first place to check is the ventilation. Make sure there is no lint in the lint screen, and all the way from the dryer to the outside of the house.
Thanks, thank you, you were right this fix the problem. the tube was stuff with moist lint very strange. but thanks again Jake
