josmoe
#1 Posted : Friday, January 15, 2010 11:00:14 AM(UTC)
josmoe
Gas dryer will ignite usually at start up but when it goes into cool down mode? it won't ignite again. You can see the ignitor glow but not light. It will take 2 or 3 cycles on the highest setting to dry clothes. I just joined the forum today and several other people have a problem with the coil or gas valve coil. This problem started after I cleaned out the lint in the back of the dryer. ??? Help is greatly appreciated.
#2 Posted : Friday, January 15, 2010 3:56:08 PM(UTC)
This is one of the most common problems with gas dryers. The gas valve coils loosing their capacity with heat.
- The coil kit Part number: AP3094251
josmoe
#3 Posted : Wednesday, January 20, 2010 6:35:59 AM(UTC)
josmoe
how do you test the coil? Do you check for continuity or what? Can you remove it without breaking it in the process? I can still use it even though it takes two to three cycles to dry clothes.
#4 Posted : Wednesday, January 20, 2010 4:26:09 PM(UTC)
...The gas valve coils loosing their capacity with heat...
You can not test them in such situation. Just replace.
You can find some useful information in one of our previous posts: http://forum.appliancepartspros...ace-coils-gas-valve.html
josmoe
#5 Posted : Thursday, January 21, 2010 6:24:16 AM(UTC)
josmoe
Dear Gene,
Thanks for your advice, I will let you know if that takes care of the problem. I do have one question before I order the coil kit, I checked the part number out at searspartsdirect.com and didn't get a match. Sears is telling me the number is 12001349. Can I get a number off the coil itself or is the part number AP3094251 work with several units? Thanks for all your help. Joe
#6 Posted : Thursday, January 21, 2010 11:25:52 AM(UTC)
The part number 12001349 is old Maytag part number. Whirlpool bought Maytag last year and changed all Maytag part numbers. Whirlpool part number for the coil kit 279834 is Appliance Parts Pros Part number: AP3094251
This coil kit will work with all gas dryers.
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
