matt wyatt
#1 Posted : Wednesday, January 13, 2010 1:20:09 PM(UTC)
matt wyatt
my maytag neptune washer dryer combodoesnt go through the spin cycle.Iv check the pump and the belt both seem fine. Washer works fine in all cycles but spin mode.
sidfink43
#2 Posted : Friday, January 15, 2010 9:51:16 AM(UTC)
sidfink43
This product is based on the Maytag Neptune washer which is one of the most troubled washer products ever made.
Maytag redesigned the motor and motor control, and that might be your problem. Check with maytag and see if they will send you a replacement kit under warranty. If not you will have to try to troubleshoot the machine.
Here is a tech bulletin on the new motor/motor control assembly.
http://www.servicematters.com/m...rary/docs/TCL-0014-B.pdf
and here is a tech bulletin on your control board, although that does not seem likely to be the problem.
http://www.servicematters.com/m...ary/docs/TDL-0052A-B.pdf
and here is a service manual for your model.
http://www.servicematters.com/m...ibrary/docs/16009127.pdf
Spin Cycle Problems (Washer Repair)
by btmullaney 11/21/2014 5:10:45 AM(UTC)
GE Spacemaker spin cycle problems (Washer Repair)
by Kristal9 6/16/2013 8:17:51 AM(UTC)
by Amy Pirrone 8/24/2011 8:36:34 AM(UTC)
by discher 2/23/2011 4:14:36 PM(UTC)
Kenmore Spin Cycle problems (Washer Repair)
by mmerr 1/29/2011 7:48:04 AM(UTC)
GE Washer Spin Cycle Problems (Washer Repair)
by jodava 5/19/2010 1:08:39 PM(UTC)
Roper spin cycle problems. TIA! (Washer Repair)
by K.D. 1/7/2010 1:42:11 PM(UTC)
by Buckeye JIm 1/7/2010 9:02:20 AM(UTC)
Filling, Agitator and Spin cycle problems (Washer Repair)
by pz7rx8 12/30/2008 10:34:02 AM(UTC)
