wdnb01
#1 Posted : Wednesday, January 13, 2010 3:09:48 PM(UTC)
wdnb01
Have water to the dishwasher valve. I checked dishwasher float and appears free and switch is working. Pput volt meter on dishwasher valve and have 110 volts when unit is turned on, but voltage drops to 40 volts during fist cycle.
John @ Fischers
#2 Posted : Wednesday, January 13, 2010 4:44:28 PM(UTC)
John @ Fischers
Go to your main power wire connection feeding dish washer, remove wire nuts, and put your meter there, when it's off, which you should get 120v.
Turn on, and see if it drops there. Post back your findings.
#3 Posted : Wednesday, January 13, 2010 4:45:46 PM(UTC)
Replacement parts for WHIRLPOOL DU915PWPQ2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
The valve should have opened when it had 110 volts across it so I would say it needs replacing.
Only other possibility I can think of is a plugged screen filter on the input side of the valve. Remove the valve from the unit and check/clean the screen.
If OK replace the valve.
If dirty do not remove it permanently from the unit as it is there to keep crud out of the vavle which would hold it open and cause a flood.
Cannot explain the 40 volts, it could have been ghopst voltage but seems a little high.
whirlpool not getting water in the door dispenser with filter installed (Refrigerator & Freezer Repair)
by jws13 12/25/2020 1:01:34 PM(UTC)
Kitchenaid ice machine not getting water consistently (Refrigerator & Freezer Repair)
by neonot 1/2/2020 9:14:38 AM(UTC)
Ice maker not getting water (Refrigerator & Freezer Repair)
by GLP 11/25/2016 7:19:47 PM(UTC)
by Mike Sasser 9/13/2016 11:25:07 AM(UTC)
Maytag quiet series 100 not getting water inside (Dishwasher Repair)
by softball24 1/9/2015 12:54:27 PM(UTC)
Kitchenaid icemaker not getting water (Refrigerator & Freezer Repair)
by cartmom 9/18/2014 1:21:28 PM(UTC)
by awashko 3/27/2014 8:13:43 AM(UTC)
Not getting water (Dishwasher Repair)
by LDOCHOP 8/12/2013 9:36:09 PM(UTC)
ice maker not getting water (Refrigerator & Freezer Repair)
by jmr82 2/4/2013 10:01:51 PM(UTC)
DW not getting water (Dishwasher Repair)
by digidutch 9/6/2012 1:08:35 PM(UTC)
by markplee@comcast.net 4/23/2012 7:58:24 AM(UTC)
GE not getting water (Dishwasher Repair)
by pdy9880 4/14/2012 3:35:27 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
by redgtfour 2/19/2012 2:00:54 PM(UTC)
ge monogram - ice maker not getting water (Refrigerator & Freezer Repair)
by jmeurer 12/23/2011 8:41:41 PM(UTC)
