Donasking
#1 Posted : 17 years ago
Donasking
THe Control Lock Indicator light is always lit. None of the selection buttons work. As the manual suggests, I did hold down the No Heat Dry pad for four seconds. This did not correct the problem. Why is this happening? :confused:
#2 Posted : 17 years ago
Most likely the problem caused by a one or more stuck pads on the key panel.
In order to provide the right part number for the console assembly for your dishwasher I need the complete model number and the color of the dishwasher.
Donasking
#3 Posted : 17 years ago
Donasking
Note: Pressing any of the keys causes the control lock to flash three times but, nothing happens.
Model number is 665 and its' color is white.
Donasking
#4 Posted : 17 years ago
Donasking
I think thgis is what you want as the full model number. 665.15951793
#5 Posted : 17 years ago
I also need the color of the control panel.
Donasking
#6 Posted : 17 years ago
Donasking
It is white.
#7 Posted : 17 years ago
The part number for the membrane switch for your dishwasher is AP3096907.
Good luck.
GE Harmony washer control locked in notification mode (Washer Repair)
by rwoosley101 10 years ago
Control lock light blinking and won' t reset (Dishwasher Repair)
by Ford4000 11 years ago
Control locked (Washer Repair)
by Bluevette70 12 years ago
kitchen aid superba control lock (Oven Repair (including Ranges and Cooktops))
by julesygirl 12 years ago
washer control lock (Washer Repair)
by dcar 13 years ago
Control Lock button is stuck "on." (Washer Repair)
by Andi02 13 years ago
Whirlpool Control Lock/Unlock (Washer Repair)
by chrisjones1211 13 years ago
machine stopped and control lock light came on .now that its off it still won't work (Washer Repair)
by lauribob 14 years ago
CONTROL LOCKED light on (Washer Repair)
by anthonypeay 14 years ago
control lock (Dryer Repair)
by Lina 14 years ago
control lock light on (Dishwasher Repair)
by peter pirri 14 years ago
Control locked (Dryer Repair)
by gary6*10 14 years ago
Whirlpool washer control locked (Washer Repair)
by bate 15 years ago
Whirlpool Duet Dryer Control Locked (Dryer Repair)
by Help in Virginia Beach 15 years ago
Control Locked light on (Washer Repair)
by firemangary@gmail.com 15 years ago
