AppliancePartsPros.com
Appliance Repair Help
Washer Repair
machine stopped and control lock light came on .now that its off it still won't work
Washer won't start. control locked light came on . I unpluged over night to try to re-boot. Light went off but machine still won't start
Look under the top cover and you should find some tech notes that tell you how to put it into a diagnostic mode and generate error codes.
I would focus on the door lock assembly and associated wiring. If it will not go into test mode, the main control unit may be a problem.
Washer Repair
