mekmak
#1 Posted : Friday, January 8, 2010 7:04:44 AM(UTC)
mekmak
dishwasher will not drain. motor runs and wash cycle works fine. During drain cycle motor runs and solenoid drops but nothing happens. I have checked for clogs in the line and disposal and have found none. What cound be the problem?
#2 Posted : Friday, January 8, 2010 8:53:40 AM(UTC)
Replacement parts for General Electric GSD4010Z07AA Dishwasher | AppliancePartsPros.com
I can think of two things.
Check the piston and Nut assembly Item 564 in Section 2. It is under the screened cover at the back inside the machine, it unscrews.
If it does not seal during drain water will be diverted back into the tub instead of out the drain.
The wash/drain flapper valve on the solenoid linkage may have come loose.
Also there is often a black seal in the center of the flapper that may be missing so all the water does not go out the drain.
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Dishwasher will not drain at end of cycle ... (Dishwasher Repair)
by dkim73 5/10/2011 7:48:46 AM(UTC)
GE Profile Dishwasher will not drain completely (Dishwasher Repair)
by michellemb 1/5/2011 8:05:52 AM(UTC)
Maytag dishwasher will not drain (Dishwasher Repair)
by rod.barnes 12/15/2010 3:46:38 PM(UTC)
GE QuietPower Dishwasher will not drain 100% (Dishwasher Repair)
by kjac3585 10/18/2010 5:48:36 PM(UTC)
White Westinghouse Dishwasher will not drain (Dishwasher Repair)
by Guardian305 10/1/2010 11:38:11 AM(UTC)
Maytag Dishwasher will not drain completely! (Dishwasher Repair)
by dahilife 8/9/2010 8:43:50 AM(UTC)
GE Profile dishwasher will not drain (Dishwasher Repair)
by pajero378 7/30/2010 11:10:20 AM(UTC)
GR p Profile dishwasher will not drain (Dishwasher Repair)
by parardise1 6/23/2010 6:17:52 AM(UTC)
dishwasher will not drain (drain pump is new) (Dishwasher Repair)
by jkda1975 4/6/2010 11:28:41 AM(UTC)
by dstoner 1/30/2010 6:20:05 AM(UTC)
Frigidaire Dishwasher will not drain....... (Dishwasher Repair)
by FDAR 1/9/2010 1:16:11 PM(UTC)
by Stardell 12/10/2009 8:21:02 PM(UTC)
by brussdogg79 12/1/2009 4:40:55 AM(UTC)
