faudlo
#1 Posted : Tuesday, December 22, 2009 6:37:22 AM(UTC)
faudlo
Hello,
My Gas Dryer is not heating. I have checked the gas line, that is open, I exchanged the ignitor and the radiant sensor. Unfortunately, it still does not heat. Could somebody please explain to me , what the root cause for the problem could be. I have the parts list for the dryer and could order the part to be replaced.
Thanks,
faudlo
#2 Posted : Tuesday, December 22, 2009 4:43:43 PM(UTC)
The parts you've replaced are not common.
There are four more parts left in the heating circuit besides the timer which you have not replaced yet. :)
My question is: would you like me just to name them so you can replace them all, or you would like to diagnose the problem and replace the exact bad part?
If your choice is the second scenario, then you have to have a simple ohmmeter and I'll be more than glad to guide you through the troubleshooting.
Let me know when you ready.
faudlo
#3 Posted : Thursday, December 24, 2009 5:02:51 AM(UTC)
faudlo
Thanks Gene,
Sorry i just checked my e-mail this morning. The two options:
Tell me the parts in question. I still need to buy a simple ohmmeter. Perhaps I can do it today. I really appreciate your help!!
Faudlo.
kayakcrzy
#4 Posted : Thursday, December 24, 2009 5:14:09 AM(UTC)
kayakcrzy
Let me help you out here. I imagine the the ignitor coil is not coming on. The common problem with this is the thermal fuse in the rear is bad. Here is what I want you to do to check it. Take the back off the dryer, and locate the thermal fuse. It is white, and about an inch and a half long by a half inch wide. It has 2 wires coming to it, and is held in by one screw. Take the 2 wires off of the thermal fuse, and put the terminal ends together, to jump out the fuse. Put a little tape around the terminal ends to keep them together, and to be sure they do not hit metal. Then plug the dryer back in, and see if it works. I bet it Does!!!!! If it does, replace the fuse. DO NOT RUN the dryer with the fuse jumped out, It is the only thing stoping the dryer from burning down the house. UNDERSTOOD!!!!!!!! Let me know how it goes. Tom ApplianceEducator.com
faudlo
#5 Posted : Saturday, December 26, 2009 5:24:34 AM(UTC)
faudlo
Hello Tom,
Thanks for the advise, I will check it out today.
will tell you tomorrow how it went.
faudlo.
kayakcrzy
#6 Posted : Saturday, December 26, 2009 11:57:41 AM(UTC)
kayakcrzy
Good Luck!! Tom ApplianceEducator.com
faudlo
#7 Posted : Sunday, December 27, 2009 1:27:36 PM(UTC)
faudlo
Thanks Tom,
This was the problem. I checked it out and shortcircuting the fuse the dryer was heating. Now I will replace the fuse!
Thank you very much for your help!
falk (faudlo)
kayakcrzy
#8 Posted : Monday, December 28, 2009 4:20:14 AM(UTC)
kayakcrzy
Originally Posted by: faudlo Go to Quoted Post
Thanks Tom,
falk (faudlo)
Good Job!!! That is the way to save the cash!!! Tom ApplianceEducator.com
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
