6 Pages«<23456>
vikkaraja
#31 Posted : Monday, December 21, 2009 6:27:13 PM(UTC)
vikkaraja
No, ignitor does not spark whenever I try to turn it on, But I can see spark whenever I try to light one of the other ones. Yes it does make clicking noise.
Thanks,
Lex
#32 Posted : Wednesday, December 23, 2009 7:12:07 PM(UTC)
Lex,
Most likely the problem is a bad ignition switch for this burner (#323 on the diagram).
- The ignition (gas valve) switch Part number: AP3191247
vikkaraja
#33 Posted : Friday, December 25, 2009 4:43:54 PM(UTC)
vikkaraja
Gene, what is the function of this part? Where is this part installed on the stove?
Thanks,
Lex
#34 Posted : Friday, December 25, 2009 7:47:45 PM(UTC)
There are four of such switches. They are located on top of the gas burner valve (under the knob). It turns the ignition on when you turn the knob on. Check the diagrams.
vikkaraja
#35 Posted : Monday, December 28, 2009 2:54:21 PM(UTC)
vikkaraja
Hi Gene, how do I remove it without disturbing any other parts removal. Like you said there are 4 of these,but to remove only one I am just trying to see what is best method. Please help . Thanks again and Happy New Year.
Lex
#36 Posted : Monday, December 28, 2009 3:31:20 PM(UTC)
Lex,
Unfortunately I did not work with such ranges or it was long time ago. Any way you have to remove all knobs and the control panel in order to reach this switch. click on the link from the previous reply and use the diagrams. No manuals for such old model available as well.
vikkaraja
#37 Posted : Saturday, February 6, 2010 5:48:48 AM(UTC)
vikkaraja
Lex,
Thanks Gene for all your help. My stove works fine now just like it sup[pose to.
#38 Posted : Sunday, February 7, 2010 5:56:57 PM(UTC)
You are welcome. I'm glad you were able to fix it.
shanodog
#39 Posted : Thursday, December 15, 2011 7:29:30 PM(UTC)
shanodog
Hi All, Our XL44 (JGBP24GRN6AD) stopped automatically lighting the 2 left burners about a year ago. A month or so later, the other side stopped. We have gas (light it with matches) and would like to get the starter working again. No clicking sounds, no ignition happening.
Any ideas? Is it a relatively simple fix? Thank you so much for your help! Just getting worried when the mother in law comes over and cant get the burner to light and leaves the gas on...not pretty.
#40 Posted : Friday, December 16, 2011 4:23:32 PM(UTC)
Very likely the problem is a bad spark module, but the model number you posted does not come up. Verify and repost it please.
Guest (5)
6 Pages«<23456>
