Gene, it has been over a year and the stove top works great! Now I get a call from the wife telling me that the oven is not 'heating up'. When I looked, it appears not to ignite. I smell a little gas, but no flame. I tried the broiler, and that fired up with no problem. I know she's looking for a new unit, but hey, I have to keep my man card intact!
Hello, Sounds like the problem is a bad Bake igniter. Check for 120 VAC to the igniter while the control calls for Bake. If the reading is correct, replace the igniter. - The oven igniter Part number: WB2X9154
Thank you Gene. Is it an easy replacement? Do you have any tips?
Thank you so much!
This job is not too difficult if you know how to handle a simple tools. The instructions are attached to the post. Gene.
