mikecouvy
#1 Posted : Monday, December 21, 2009 3:41:07 PM(UTC)
mikecouvy
The water dispensor has no water flow. The valve at the rear of the refrigerator is working. When I separated the water supply line at the bottom of the door, the water would flow to the point when the dispenser is activated. It appears that the problem is between the bottom of the door and the water outlet at the dispenor. ANy help is appreciated.
Mike
mikecouvy
#2 Posted : Monday, December 21, 2009 3:54:45 PM(UTC)
mikecouvy
Some additonal information I failed to post. The fridge is manufactured by LG. The water flows to the quick connect at the bottom of the door.
Mike
woodchuckie
#3 Posted : Monday, December 21, 2009 4:47:08 PM(UTC)
woodchuckie
Your water line is probably frozen in the door
leave the door open till it thaws. You can cover the opening with a blanket to keep it from thawing the food.
GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Part Details - GE DISPENSER WATER TUBE, part number: AP4318572
jefwil
#4 Posted : Monday, December 28, 2009 6:58:46 PM(UTC)
jefwil
I had same problem with water to the bottom of door but not at dispenser. I inserted a smaller diamater tube through dispenser tube as far as it would go. I then depressed the water lever and poured a small amount of hot water through my smaller tube. In about 30 seconds the water was flowing again.
mac reichenbach
#5 Posted : Tuesday, December 29, 2009 3:49:23 PM(UTC)
mac reichenbach
did you get any response to your question?
Mike
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Kenmore Elite 795.72489.411 water dispenser not working (Refrigerator & Freezer Repair)
by fjfagergren 5/31/2021 1:16:48 PM(UTC)
Water dispenser not working hums but no water. (Refrigerator & Freezer Repair)
by mouse51180 4/5/2019 4:44:02 PM(UTC)
Water Dispenser not working but ice maker is still working (Refrigerator & Freezer Repair)
by Bobby-Houston 1/14/2019 1:01:20 PM(UTC)
by tmeiss 8/29/2016 2:11:03 PM(UTC)
Water dispenser not working, parts replaced (Refrigerator & Freezer Repair)
by pdog 5/11/2015 4:23:01 PM(UTC)
GE Refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Jinxpalm 3/4/2015 1:26:52 PM(UTC)
Water dispenser not working with filter. Works without filter (Refrigerator & Freezer Repair)
by kathut 9/2/2014 7:25:16 AM(UTC)
by help810 8/3/2014 6:33:56 PM(UTC)
LG Frig Ice & Water dispenser not working, No Light (Refrigerator & Freezer Repair)
by LG_Frig_Dispenser_Problem 12/20/2013 4:03:40 PM(UTC)
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11/12/2013 11:44:19 AM(UTC)
produce drawer too cold; water dispenser not working (Refrigerator & Freezer Repair)
by houseofreg 5/13/2013 5:12:15 AM(UTC)
water dispenser not working after actuator replacement (Refrigerator & Freezer Repair)
by rd27 3/13/2013 10:55:05 AM(UTC)
