jbntouch
#1 Posted : Friday, February 29, 2008 4:54:00 PM(UTC)
jbntouch
My garbage disposal just started humming! Nothing is in it, I looked this model up and there is only a screw at the bottom, what does this go to? There is nothing that up can stick anything in to loosen. Is there any other way to loosen the blade.
roycreamer
#2 Posted : Friday, February 29, 2008 6:39:30 PM(UTC)
roycreamer
Groups: Expert
get a mop handle (or something similar) and put it down there and twist around with a large circular motion.
make sure it's off...
if you replace it, get an insinkerator... anything except a ge
handyman101
#3 Posted : Wednesday, May 14, 2008 8:45:39 AM(UTC)
handyman101
i also had the same problem problem. GE garbage disposal just pissed me off.
norma1231
#4 Posted : Friday, April 22, 2011 6:22:36 AM(UTC)
norma1231
if you replace it, get an insinkerator... anything except a ge[
thanks so much i did that and it is working the screw at the bottom goes to the electricity..
allanmurray20
#5 Posted : Wednesday, May 8, 2013 9:43:55 AM(UTC)
allanmurray20
Such an interesting topic to discuss just like discussing about
tree pruning vancouver while surfing goggle maps.
allanmurray20
#6 Posted : Thursday, May 9, 2013 8:06:10 AM(UTC)
allanmurray20
Try using a motor or mechanical oil to loosen the screw, it might be full of rust. In door repairs it is often used such as in garage door services in alberta and door maintenance.
jc920060
#7 Posted : Friday, August 9, 2013 1:49:35 AM(UTC)
jc920060
Hello Friends,
I am new on this forum.
please add me on you conversation.
Thank you in advance.
_________________________________
Immigration Canada
India Tour
Guest (8)
