danichris
#1 Posted : Monday, December 14, 2009 6:12:06 PM(UTC)
danichris
my oven has power but oven and cooktop will not get hot
gabe_1981
#2 Posted : Monday, December 14, 2009 6:35:34 PM(UTC)
gabe_1981
Please post your complete model number
danichris
#3 Posted : Monday, December 14, 2009 6:57:26 PM(UTC)
danichris
frigidarees300
gabe_1981
#4 Posted : Monday, December 14, 2009 7:00:38 PM(UTC)
gabe_1981
The model number will be located on a plate on the inner door housing or the housing around the bottom drawer ... You will see model number and serial number both on this plate
#5 Posted : Tuesday, December 15, 2009 3:22:12 AM(UTC)
Try flipping the breaker off/on slowly a couple times. Often you can loose half the line without actually tripping the breaker. The heating elements require both sides (240 volts) whereas the control panel, lights etc. just require half the line (120 volts).
If this does nothing check the power at the receptacle.
L1 to L2 should be 240 volts
If OK
Unplug the unit
Check the terminal strip in the unit to ensure a wire has not burned off.
If OK
Either check for power at the terminal strip or check the line cord wires for continuity.
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 7/28/2022 3:00:04 PM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
please help kitchen aid fridge noise (Refrigerator & Freezer Repair)
by marcelmcesar 8/3/2021 4:54:39 PM(UTC)
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
by swingbyte 4/1/2021 11:35:24 PM(UTC)
Fisher & Paykel DEIX2 Dryer Keeps tripping t-stat Please Help (Dryer Repair)
by hotlicksexhaust 5/7/2020 8:22:39 AM(UTC)
Silence is definitely not Golden (LG) ... Please help (Microwave Repair)
by benh1234 1/16/2019 2:13:22 PM(UTC)
Please Help - Whirlpool WFG524SLAS (Oven Repair (including Ranges and Cooktops))
by yozzomp 12/5/2018 1:27:04 PM(UTC)
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 3/23/2018 2:24:04 PM(UTC)
Mystery part loose in box - please help identify! (Refrigerator & Freezer Repair)
by xkandakex 12/14/2017 10:36:27 AM(UTC)
PLEASE HELP! Quiet Partner III Cancel, Rinse Only Lights Blinking (Dishwasher Repair)
by zed40 3/24/2017 6:16:49 PM(UTC)
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 2/11/2017 8:02:28 AM(UTC)
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 2/5/2017 8:12:19 AM(UTC)
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Please help with my GE replacement motor wiring (Dryer Repair)
by Mjutton 6/29/2016 7:36:12 PM(UTC)
