here4real
#1 Posted : Monday, December 14, 2009 1:08:55 PM(UTC)
here4real
The glass in the door has cracked. Handle broken too. It seems I need part 338 and 365. I have 3 questions. 1) It looks easy enough to replace the glass assuming I purchase the replacement. However, are all of the other pieces of the door reusable, i.e. when I take it apart to remove the broken glass can I reuse the old pieces when reassembling? 2) The handle I have is in 3 parts - 2 are still in the oven door and the piece in the middle broke. Will this handle, 365, replace all 3 pieces? 3) Is it possible to just buy a new door instead of the pieces? Would that be cheaper?
Thanks!
escanne
#2 Posted : Friday, December 18, 2009 10:00:25 AM(UTC)
escanne
The inner glass on my oven is crack, can i still use the oven safely and how do I replace the glass. I have a glass on order
escanne
#3 Posted : Friday, December 18, 2009 10:04:37 AM(UTC)
escanne
should I replace the oven or replace the glass.
cracked glass top gas (Oven Repair (including Ranges and Cooktops))
by elricw 2/20/2011 5:07:22 PM(UTC)
Cracked glass top stive (Oven Repair (including Ranges and Cooktops))
by JShockley 12/11/2010 10:41:48 AM(UTC)
Cracked Glass in Door of older Magic Chef Wall Oven (Oven Repair (including Ranges and Cooktops))
by mark2741 2/10/2010 7:01:47 AM(UTC)
Cracked Glass Top (Oven Repair (including Ranges and Cooktops))
by bnmmunson 10/9/2009 9:52:59 AM(UTC)
Cracked glass (Oven Repair (including Ranges and Cooktops))
by TheresaZ 7/2/2009 3:43:38 PM(UTC)
cracked glass cook top (Oven Repair (including Ranges and Cooktops))
by zell66 7/1/2009 3:52:54 PM(UTC)
Replacing Cracked Glass on Cooktop (Oven Repair (including Ranges and Cooktops))
by jusacruiser 3/30/2009 12:02:52 PM(UTC)
Need to replace cracked glass cooktop (Oven Repair (including Ranges and Cooktops))
by csbunnell 3/2/2009 9:42:02 AM(UTC)
Cracked Glass (Oven Repair (including Ranges and Cooktops))
by plasmagames 2/21/2009 7:15:18 PM(UTC)
Cracked glass stovetop (Oven Repair (including Ranges and Cooktops))
by paulk1 11/1/2008 6:15:02 PM(UTC)
Cracked Glass Cooktop (Oven Repair (including Ranges and Cooktops))
by ROBERT PAGE 6/16/2008 3:43:33 AM(UTC)
Cracked glass on oven (Oven Repair (including Ranges and Cooktops))
by wessell 2/3/2008 8:42:44 PM(UTC)
Frigidaire cracked glass cooktop (Oven Repair (including Ranges and Cooktops))
by mchome76 1/1/2008 2:06:37 PM(UTC)
