I spilled some water on the inside glass of my Kitchenaid Superba oven door and it cracked.
Is it safe to use the oven? Can I replace the glass myself? Help! :eek:
If the inner door glass just cracked but still in place you probably can use the oven for cooking but not for the self cleaning. Due to safety issue it's better to replace it. This part is not too difficult to replace yourself. Remove the door from the range and place it on a flat surface with the front of the door facing down. Remove the screws holding the inner door panel and remove the panel. The inner door glass comes as a kit and it is much easier to understand the replacement process when you will see the kit. - The part number for the inner glass kit is AP3124577 Here are the break down diagrams for the Kitchen Aid range Model KGST307FWH0Gene.
I appreciate the information very much. Too bad I broke such an expensive part...:(
:confused: Hi, I have Kitchen Aid wall oven w/ model # KEBC107KSS03.
The original outer glass was shattered even when the owen was not in use.
I ordered a new glass w/part # W10200754 from AppliancePartsPros.com.
I did not have any problem installing the new glass, The problem was in that we have used the oven one time, no problem. Next day I heard a crack noise to find out the installed new glass cracked.
The oven even was not on, I started wondering what is causing that shatter the glass. I would like to find out the cause of the problem before I pay another over $70 dollars for a new glass. Any advice for me? Thank you..
