nike
#1 Posted : Sunday, August 19, 2007 4:29:03 PM(UTC)
nike
The Key Pad Does Not Respond To Individual Commands. Range Top Works Oven And Broiler Does Not Work. Door Lock Symbol And Light Flashes After Pushing Touch Pad To Start Oven. What Can Be Done To Resolve This Problem? MODEL NUMBER #FGF354BGWE
Admin / APP Team
#2 Posted : Sunday, August 19, 2007 5:25:33 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Nike,
Please post the actual model number of the range. 316065306 is a part number for a warning plate. Use our Model Number Locator to find the right tag on the range.
nike
#3 Posted : Monday, August 20, 2007 3:58:48 PM(UTC)
nike
The Correct Model Number Is #fgf354bgwe.
Admin / APP Team
#4 Posted : Monday, August 20, 2007 11:47:36 PM(UTC)
Admin / APP Team
Groups:
Sounds to me like the ERC (oven clock) is bad. On this model, oven clock and touch pad are part of one unit, however the overlay with all the buttons printed on it is a sticker and will need be replaced also, since you won't be able to re-use it.
- Replacement clock
- Replacement overlay
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
frigidaire gas range (Oven Repair (including Ranges and Cooktops))
by Benitojuarez 1/27/2018 10:39:13 AM(UTC)
Frigidaire gas range will only ignite one at a time (Oven Repair (including Ranges and Cooktops))
by KevinD76 4/6/2015 8:07:28 AM(UTC)
Frigidaire gas range: Bake function inop (Oven Repair (including Ranges and Cooktops))
by Dave1175 3/6/2014 9:47:20 AM(UTC)
Frigidaire Gas Range/Oven (Oven Repair (including Ranges and Cooktops))
by beebem97 8/16/2013 2:28:34 PM(UTC)
Frigidaire gas range control panel--price? (Oven Repair (including Ranges and Cooktops))
by bpjdoc 8/3/2012 6:18:25 AM(UTC)
Frigidaire gas range model fgf379wecs....the oven doesn't always light off (Oven Repair (including Ranges and Cooktops))
by iajet 2/13/2012 7:10:12 AM(UTC)
Frigidaire gas range cook top grates (Oven Repair (including Ranges and Cooktops))
by learjetman 12/11/2011 5:39:05 PM(UTC)
frigidaire gas range oven (Oven Repair (including Ranges and Cooktops))
by repairmann 11/3/2011 3:56:48 PM(UTC)
by larry belanger 7/5/2010 2:11:10 PM(UTC)
Frigidaire gas range display out, oven not working (Oven Repair (including Ranges and Cooktops))
by landas214 4/29/2010 11:13:35 AM(UTC)
by snudden4 2/6/2010 3:28:20 PM(UTC)
frigidaire gas range control dim/not working (Oven Repair (including Ranges and Cooktops))
by kir26 9/14/2008 9:01:45 AM(UTC)
Frigidaire Gas Range wont ignite! Spark Module? (Oven Repair (including Ranges and Cooktops))
by Tractorshaft 8/20/2008 9:35:15 AM(UTC)
