KevinD76
#1 Posted : Monday, April 6, 2015 8:07:28 AM(UTC)
KevinD76
I have a 10 year old Frigidaire gas range, and can't get the bake and broil to ignite at the same time. I am getting 120V going into the #4 terminal, and can get the broiler to ignite, but not the bake element. After extensive troubleshooting and parts changing, I have cut and crossed the orange and blue (crossing the bake and broil outputs on the #1 and #2 terminals) and the bake will ignite, but not the broil. I am at a loss on why this is happening. I have replaced the ignitor for the bake pilot light, thinking that was it, then the control board and that didn't fix it. I've even went as far as changing (re-soldering) the bake relay on the control board thinking that the problem and still no fix. Any thoughts, wife is ready for a new range, but am sure its a simple fix that I am missing?
KevinD76
#2 Posted : Monday, April 6, 2015 8:12:46 AM(UTC)
KevinD76
Sorry about original post, the wires that I crossed were blue and yellow, not blue and orange out of the terminal wiring harness.
ppoomi
#3 Posted : Monday, April 6, 2015 11:07:46 PM(UTC)
ppoomi
They replaced it and it worked a while and the thermostat went out again. The parts diagram on this website show two thermostats.
pass4sure 100-101 brain dump
