snudden4
#1 Posted : Saturday, February 6, 2010 3:28:20 PM(UTC)
snudden4
One of the digits on display for clock, timer and temperature has burned out. If I flick it with my finger, it will return for a moment and then darken again. All the other digits other than the 2nd from the right are fine. For instance, instead of saying 350 degrees, it looks like 3 0 degrees. Any advice is appreciated!
ApplianceJunk
#2 Posted : Saturday, February 6, 2010 5:38:28 PM(UTC)
ApplianceJunk
You could check the board for the clock for bad connection, but chances are you will have to replace it to fix the problem.
snudden4
#3 Posted : Sunday, February 7, 2010 10:53:03 AM(UTC)
snudden4
Replace the entire board or just a part of it? Is this something my husband could handle or do we need to call a service company? About how much does a board cost? Thanks!
ApplianceJunk
#4 Posted : Sunday, February 7, 2010 11:03:04 AM(UTC)
ApplianceJunk
Here is the part for your oven.
Part Details - FRIGIDAIRE Clock/timer, part number: AP3853281
Easy enough to change.
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
frigidaire gas range (Oven Repair (including Ranges and Cooktops))
by Benitojuarez 1/27/2018 10:39:13 AM(UTC)
Frigidaire gas range will only ignite one at a time (Oven Repair (including Ranges and Cooktops))
by KevinD76 4/6/2015 8:07:28 AM(UTC)
Frigidaire gas range: Bake function inop (Oven Repair (including Ranges and Cooktops))
by Dave1175 3/6/2014 9:47:20 AM(UTC)
Frigidaire Gas Range/Oven (Oven Repair (including Ranges and Cooktops))
by beebem97 8/16/2013 2:28:34 PM(UTC)
Frigidaire gas range control panel--price? (Oven Repair (including Ranges and Cooktops))
by bpjdoc 8/3/2012 6:18:25 AM(UTC)
Frigidaire gas range model fgf379wecs....the oven doesn't always light off (Oven Repair (including Ranges and Cooktops))
by iajet 2/13/2012 7:10:12 AM(UTC)
Frigidaire gas range cook top grates (Oven Repair (including Ranges and Cooktops))
by learjetman 12/11/2011 5:39:05 PM(UTC)
frigidaire gas range oven (Oven Repair (including Ranges and Cooktops))
by repairmann 11/3/2011 3:56:48 PM(UTC)
by larry belanger 7/5/2010 2:11:10 PM(UTC)
Frigidaire gas range display out, oven not working (Oven Repair (including Ranges and Cooktops))
by landas214 4/29/2010 11:13:35 AM(UTC)
frigidaire gas range control dim/not working (Oven Repair (including Ranges and Cooktops))
by kir26 9/14/2008 9:01:45 AM(UTC)
Frigidaire Gas Range wont ignite! Spark Module? (Oven Repair (including Ranges and Cooktops))
by Tractorshaft 8/20/2008 9:35:15 AM(UTC)
by nike 8/19/2007 4:29:03 PM(UTC)
