gfroman
#1 Posted : Thursday, December 10, 2009 3:41:42 AM(UTC)
gfroman
Our dryer will not heat. We removed the heating element and took it to have it checked. Everything checked out fine. What else could be the cause of no heat? :confused:
TheDragon
#2 Posted : Thursday, December 10, 2009 5:43:40 PM(UTC)
TheDragon
I am not an expert, but I just went through the same problem
ie
there are many parts (in addition to the heating coil)
my model (Kenmore) has a fuse, thermistor, 2 overheat protection devices, a heater relay and the electric controls that tells it when/how to heat
all parts seemed to pass each test, so I replaced the electronics-
still no heat - and after some help from this Forum and more testing, just ordered a heater relay this morning
hopefully, you can get a tech manual (maybe from someone here)
and see all the parts in the heater circuitry
#3 Posted : Friday, December 11, 2009 3:10:49 AM(UTC)
Replacement parts for LEA30W models | AppliancePartsPros.com
Here is a service manual not for your exact model but the LEA30A* should be close.
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
Try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit
Check that a wire has not burned off at the unit's terminal block
If OK
Check the operating thermostat and the hi-limit thermostats both should be 0 ohms
If OK
Check the thermal fuse this is the one on the heater, should be 0 ohms.
If it is blown also replace the hi-limit thermostat as this should have regulated the temperature so this fuse did not blow.
Only proviso on this is if the original heater was grounded, if it was then the thermostat cannot regulate the temperature and therefore blew the fuse so the hi-limit is probably OK.
If the fuse is blown check that the lint filter is not coated with fabric softener residue, check that the drum seals are OK, check that the seals in the heat path are OK, clean/check the blower wheel and clean/check the vent system.
Here is a good site with additional info
http://www.applianceaid.com/dryers.html
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
