goonybird
#1 Posted : 17 years ago
goonybird
I have a HE3 front loader. When it’s get to the rinse part and the setting is cold water, it's rinses with hot water.
Have checked hoses and screen every thing seams normal. It comes coldwater out of the hose when disconnected from the machine.
Anyone have suggestions.
#2 Posted : 17 years ago
What happens if you select cold or hot water for wash cycle?
goonybird
#3 Posted : 17 years ago
goonybird
Still uses hotwater
GB
#4 Posted : 17 years ago
You got the fill hoses switched around.
goonybird
#5 Posted : 17 years ago
goonybird
have checked that too.
GB
#6 Posted : 17 years ago
Verify with a meter that you get 115 volts to the hot water solenoid when you select cold. If so, you have a bad control board. You may want to just switch the hoses to save money, or switch the wiring.
