goonybird
#1 Posted : Sunday, February 24, 2008 11:35:11 PM(UTC)
goonybird
I have a HE3 front loader. When it’s get to the rinse part and the setting is cold water, it's rinses with hot water.
Have checked hoses and screen every thing seams normal. It comes coldwater out of the hose when disconnected from the machine.
Anyone have suggestions.
#2 Posted : Monday, February 25, 2008 2:03:24 PM(UTC)
What happens if you select cold or hot water for wash cycle?
goonybird
#3 Posted : Monday, February 25, 2008 8:09:47 PM(UTC)
goonybird
Still uses hotwater
GB
#4 Posted : Monday, February 25, 2008 8:19:16 PM(UTC)
You got the fill hoses switched around.
goonybird
#5 Posted : Tuesday, February 26, 2008 8:39:54 AM(UTC)
goonybird
have checked that too.
GB
#6 Posted : Tuesday, February 26, 2008 9:30:28 AM(UTC)
Verify with a meter that you get 115 volts to the hot water solenoid when you select cold. If so, you have a bad control board. You may want to just switch the hoses to save money, or switch the wiring.
