randyhensley
#1 Posted : Sunday, December 6, 2009 11:40:52 AM(UTC)
randyhensley
My dryer will not heat. I checked the jumper wire and it is ok. What is the most common problem? Heating Element, Hi Lo Limit Thermostat or Thermal Fuse?
Randy
#2 Posted : Monday, December 7, 2009 4:14:59 AM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDE8400AYW Dryer - Ele | AppliancePartsPros.com
Here is a manual, note it is for similar models not this specific model.
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Not sure what you mean by jumper wire.
Heating Element - this would be at the top of the list
Hi Lo Limit Thermostat - also a possibility along with the cycling thermostat.
Thermal Fuse - not possible as the fuses in this unit kill power to the motor
First try flipping the breaker off/on slowly a couple times, sometimes it can loose half the line without actually tripping the breaker and the heater requires the full 240 volts. Better yet measure it at the plug
L1 to L2 should be 240 volts
Also unplug the unit and check the wiring at the unit's terminal block to ensure a wire has not burned off.
Next unplug the unit and check the heating coil.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
