donietta
#1 Posted : Monday, February 18, 2008 5:28:45 PM(UTC)
donietta
Ok....Here's my problem. We were having a hard time getting the washer to start once you put the lid down. I called a repairman and he looked at it and said that he had "fixed it", well it will now go into the rinse cyle, but, I can't get it to fill up with water. The water will not come on at all. I have checked the simple things such as ensuring that the water is on. I am clueless right now as to what the problem could be. Any help will be greatly appreciated.:confused:
#2 Posted : Tuesday, February 19, 2008 2:43:00 PM(UTC)
Hi donietta,
The first thing I would do is check if 120V coming to the water inlet valve coils when the timer calls for water and the water temperature switch is set for warm water.
If there is 120V and no water is coming into the washer - the water inlet valve has to be replaced.
If there is no 120V and the wires to the water inlet valve are fine, let me know and we will proceed with the further diagnosis.
- The part number for the water inlet valve is AP244856
Here are the break down diagrams for the Maytag washer Model A7400
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Clothes were scortching, Now no HEAT? Frigidaire Dryer Gallery Series NEED HELP! (Dryer Repair)
by kado1976 1/13/2016 1:04:57 PM(UTC)
Need Help! Unsure of what part I need (Washer Repair)
by sara7524 5/10/2015 11:12:04 AM(UTC)
Need Help!! (Washer Repair)
by 68matthew 4/21/2015 6:46:14 PM(UTC)
obscure small commercial cooler NEED HELP!!! (Refrigerator & Freezer Repair)
by soliddrummer 3/18/2015 8:41:40 PM(UTC)
Whirpool Washer - need help! (Washer Repair)
by jbrixey1@hotmail.com 3/31/2014 5:57:44 AM(UTC)
GE Fridge not working, need help! (Refrigerator & Freezer Repair)
by robweber1 7/25/2012 4:51:04 PM(UTC)
LG Tromm Elec. Dryer is Dead. I need Help! (Dryer Repair)
by matt_a 4/1/2012 8:27:02 AM(UTC)
GE WCSE6270B2WW Need Help! (Washer Repair)
by valvano 12/23/2011 7:48:14 PM(UTC)
Oven won't heat up, need help! (Oven Repair (including Ranges and Cooktops))
by dogrobber13 8/16/2011 8:09:08 AM(UTC)
Need help! - GE Monogram Microwave not heating and buzzes!! (Microwave Repair)
by JeffGinGA 3/30/2011 12:20:23 PM(UTC)
NEED HELP! PSF26Pg (Refrigerator & Freezer Repair)
by steve1147 3/10/2011 4:21:49 PM(UTC)
washer broke need help! (Washer Repair)
by huck0804 8/19/2010 7:38:53 PM(UTC)
Need Help! What do I look for? Hotpoint washer (Washer Repair)
by theresam 8/4/2010 8:15:56 AM(UTC)
kitchenaid dishwasher , Denman, need help! (Dishwasher Repair)
by fshman54 1/4/2010 5:31:38 PM(UTC)
