68matthew
#1 Posted : Tuesday, April 21, 2015 6:46:14 PM(UTC)
68matthew
Help!!
I have an LG WM0642HW and it is roughly 10 years old. When I run it through a normal wash it stops just before the spin and drain cycle. The drum just sits and it sounds like a grinding noise.
I removed the rear cover and checked the bearings. The seals are still good and there is no rust residue in the rear of the unit.
I ran a diagnostic test by pushing soil level and spin speed and then powered up the unit. The test stops with a blinking nE code and doesn't process any test at all.
What could this be? I appreciate your help.
68matthew
#2 Posted : Tuesday, April 21, 2015 7:21:36 PM(UTC)
68matthew
On the Cotton / Normal Cycle the washer starts and the drum spins. At 38 minutes, the washer stops spinning and starts a grinding noise. I am left with a drum with water and have to manually drain.
obscure small commercial cooler NEED HELP!!! (Refrigerator & Freezer Repair)
by soliddrummer 3/18/2015 8:41:40 PM(UTC)
Blew a Capacitor after Repair - Need Help!! (Washer Repair)
by andreasattic4kids 1/24/2009 5:34:02 PM(UTC)
Freezer works but not fridge Need Help!!!!! (Refrigerator & Freezer Repair)
by msshottet 2/18/2008 11:13:24 AM(UTC)
