2 Pages<12
martinezc2006
#11 Posted : Friday, February 15, 2008 6:49:07 PM(UTC)
martinezc2006
your rite the zoom worked. now time 2 order the part. its in the location of the popping noise! so well c!! ill keep u up dated. thanks!!!!!
martinezc2006
#12 Posted : Friday, February 15, 2008 6:58:35 PM(UTC)
martinezc2006
Is The Part Easy To Change?
suchen
#13 Posted : Monday, February 18, 2008 9:34:31 AM(UTC)
suchen
We had similar problem several months ago. There is little fan with motor in the freezer compartment. you have to remove the racks to access the wall and see if the fan is not moving you have to replace it. if it's moving check to see if the panel for the wall is pressing on it. It happened to us, we bought new part and replaced and still didn't work. it was the panel pressing on the fan. and hope your problem stops there. if fan is not blowing, no cold air goes to the other side.
Hope this helps you. now we have another problem that i have to find someone to help me.
Such a terrible product, so many problems in the past, never buy maytag again, even the dishwaher is bad, only last me three years
martinezc2006
#14 Posted : Wednesday, February 20, 2008 3:22:49 PM(UTC)
martinezc2006
Hi Gene,
I Ordered The Parts That U Suggested And I Channged Them. It Didnt Solve The Problem. Any More Ideas?
In The Bottom Part Where The Freezer Is, I Noticed In The Ice Bucket Where The Automatic Icemaker Is The Ices Looks Like It Was Melted And Refroze.
martinezc2006
#15 Posted : Wednesday, February 20, 2008 3:24:38 PM(UTC)
martinezc2006
AIR IS MOVING ARUND DOWN IN THE FREEZER, BUT ""NOT AT ALL"" IN THE TOP WHERE THE FRIDGE IS!!
sorry for all the caps! im not yelling! =+)
#16 Posted : Wednesday, February 20, 2008 3:32:02 PM(UTC)
Originally Posted by: martinezc2006 Go to Quoted Post
hello!
I checked and there is no frost build up.
The temp in the freezer seems fine. EVERYTHING IS STILL FROZEN AND EVEN ICE IS BEING MADE. ( SORRY I DONT HAVE ANYTHING TO CHECK THE EXACT TEMP)
No air moving in the fridge.
There IS air moving in the freezer.
THANKS!!
I need you to measure the temperature in the freezer. You can use any kind of refrigerator thermometer from a hardware store or you can order this one: AP3549145
Make sure the fan in the freezer is working and there is no frost on the back wall.
martinezc2006
#17 Posted : Wednesday, February 27, 2008 3:54:16 PM(UTC)
martinezc2006
25 degrees f
martinezc2006
#18 Posted : Wednesday, February 27, 2008 3:55:50 PM(UTC)
martinezc2006
in the freezer
martinezc2006
#19 Posted : Wednesday, February 27, 2008 3:57:57 PM(UTC)
martinezc2006
:confused: were the ice maker is.........ice is being made,melted the refrozen
#20 Posted : Wednesday, February 27, 2008 4:34:50 PM(UTC)
If there is no frost on the back panel in the freezer and the fan is working, then probably the cooling system is low on Freon. Such problem has to be fixed by a certified tech. If your fridge is less than five years old - it should be under the manufacturer warranty.
Guest (6)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Maytag french door fridge freezer on bottom (Refrigerator & Freezer Repair)
by lshamim 8/18/2009 4:51:55 AM(UTC)
Maytag French Door Fridge OD. (Refrigerator & Freezer Repair)
by knittingtrains 3/16/2009 11:17:19 AM(UTC)
2 Pages<12
