lshamim
#1 Posted : Tuesday, August 18, 2009 4:51:55 AM(UTC)
lshamim
noticed last night Freezer was warmer than normal and ice maker not making any ice. all contents were thawed. fridge above is working normal.
freezer makes buzzing sound with a click at the end every few minutes
Frank / APP Team
#2 Posted : Tuesday, August 18, 2009 5:07:50 AM(UTC)
Frank / APP Team
That is not a real good sign. If the noise you're hearing is the compressor trying to start and the overload then kicking it off you may have a compressor problem. Depending on the age of the unit, you may want to get a hold of an authorized servicer, the compressor may still be under warranty.
lshamim
#3 Posted : Tuesday, August 18, 2009 5:17:08 AM(UTC)
lshamim
how can I be certain if it's the compressor? Is there something i can look at or see before i call a pro?
lshamim
#4 Posted : Tuesday, August 18, 2009 5:18:14 AM(UTC)
lshamim
if it is the compressor - what's the average cost of part and labor?
Frank / APP Team
#5 Posted : Tuesday, August 18, 2009 5:36:19 AM(UTC)
Frank / APP Team
You need to get us a good model number first for me to look up the part. The one you listed isn't a valid #. I can get you a price for the part, but the labor piece will vary. It it will expensive though. Just guessing but, somewhere between $350 up to $600.
You'll need to pull the unit out from the wall and get behind it. There is a fan back there that keeps the comp running cool, make sure it's running. When you're back there, if you wait a few minutes, if it's the comp you'll hear it try and start. If it's already running when you're back there, then you can probably rule it out. From your description it does sound like it though.
lshamim
#6 Posted : Tuesday, August 18, 2009 6:41:26 AM(UTC)
lshamim
model number is MFD2560HES and serial is 10884272er
i realized that both the refrigerator and freezer are not cool enough. the fridge portion has also warmed up a bit since last night. HELP
Frank / APP Team
#7 Posted : Tuesday, August 18, 2009 7:14:18 AM(UTC)
Frank / APP Team
If the compressor isn't running it will sure affect both sections. Have you done what I mentioned in my previous post?
Below is the part number for the compressor and price is $248.83. You'll have to check with local servicers to find out how much they would charge you for the installation if that is the problem.
Part number: AP3179960
