Garry Ramser
#1 Posted : Monday, February 4, 2008 3:35:33 PM(UTC)
Garry Ramser
The dryer goes on, no heat and the motor continues without any heat. Will move (timer) if set on time only.
#2 Posted : Tuesday, February 5, 2008 11:10:45 AM(UTC)
Hi Garry,
This is one of the most common situation.
You can find the complete troubleshooting instructions in the one of my previous posts: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
- The part number for the igniter is AP3094138
- The part number for the flame sensor is AP2910747
- The part number for the gas valve coils kit is AP3094251
Here are the break down diagrams for the Whirlpool dryer Model LGR5636EQ3
Good luck.
Garry Ramser
#3 Posted : Friday, February 8, 2008 2:21:03 PM(UTC)
Garry Ramser
Checked as your instructions indicated, ordering the thermal fuse and thermostat. Great website!! Will post back once I try the new parts. Tks:)
Garry Ramser
#4 Posted : Thursday, February 14, 2008 10:07:11 AM(UTC)
Garry Ramser
Just an update. Received parts, installed in dryer and am resently drying a load of laundry. Great site and great help. Recomending you to all my friends. Tks again
#5 Posted : Thursday, February 14, 2008 11:27:08 AM(UTC)
I'm glad you were able to fix it.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
