Brian Raynor
#1 Posted : Saturday, October 31, 2009 12:51:04 PM(UTC)
Brian Raynor
In May I had my dryer serviced because it wouldn't start: a repairman installed a new "Thermal Cut Out" and the dryer worked fine until a few days ago. The after the dryer ran on a heated cycle for ten minutes, it tripped a circuit breaker. If I set the dryer on a twenty minute setting at the end of a cycle, it runs until the end of the cycle. Also, if I run it on a no heat cycle, it will run until the end of the cycle. An electrician told me that I should test each part after the circuit has been tripped to determine which part has a "short" in it. Can you tell me where to start testing or is the problem in a different area?
Brian
Brian Raynor
#2 Posted : Saturday, October 31, 2009 1:01:39 PM(UTC)
Brian Raynor
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Brian Raynor
#3 Posted : Saturday, October 31, 2009 1:04:09 PM(UTC)
Brian Raynor
My dryer kicks off the circuit breaker after ten minutes unless I am using a non-heated cycle like "fluff." Where do I start testing to see if I have a short or defective part?
Brian
#4 Posted : Sunday, November 1, 2009 3:33:16 AM(UTC)
Replacement parts for WHIRLPOOL LER5644JQ0 | AppliancePartsPros.com
The above seems to contradict what I say below. Is very strange that it will run full cycles with high heat if you do this. I may not be understanding this correctly.
You probably will have a hard time finding this sounds like something is heating up, shorting to the frame and then when it cools the short is removed.
Two items come to mind the motor or the heating element.
The only one you can check visually is the element so I would start there.
Remove it and see if there are any signs of the element sagging and touching the case.
One other possibility would be the timer.
Also, it is always possible that your breaker is no good.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
