dunatic1
#1 Posted : Tuesday, February 5, 2008 10:26:45 AM(UTC)
dunatic1
i had an error code of f1 on my disply and i replaced electronic timer part#ap4283393 now the oven only works periodicly it will come up to temp on bake mode work for a while then completly shut off with no error code just a blank screen then you start it back up and it works fine,next day it works fine and then all of the suddin it shuts itself down again.everynow and then outof the blue it will show code f0 when im not even using oven.does this mean i have to replace touchpad also? or could it be something else thnx
#2 Posted : Wednesday, February 6, 2008 10:41:22 AM(UTC)
The cause of the "F1" error code could be a faulty control board as well as a stuck key on the key panel.
You, probably, replaced the control board without complete diagnosis.
Most likely the problem is a bad key panel.
- The part number for the key panel is AP368708
Here are the break down diagrams for the Jenn Air range Model S176W
What next if ice maker jumping shows a small spark (Refrigerator & Freezer Repair)
by JuddT 7/14/2022 2:36:01 PM(UTC)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Fridge won't start, what next??? (Refrigerator & Freezer Repair)
by gefricot 7/26/2016 10:39:13 AM(UTC)
Dryer still won't heat,what next? (Dryer Repair)
by BSTrue 12/16/2014 3:26:17 AM(UTC)
Dryer--No heat, continuity tests ok...what next? (Dryer Repair)
by davesharpe 1/5/2014 12:48:28 PM(UTC)
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 9/8/2013 7:00:44 PM(UTC)
Ice covering evaporator coils . . . What next? (Refrigerator & Freezer Repair)
by Dale.1 7/9/2013 8:44:46 PM(UTC)
frigidaire wont drain, pump replaced - what next? (Dishwasher Repair)
by mh1078 4/1/2011 10:25:26 AM(UTC)
whirlpool burner shuts off-what next (Dryer Repair)
by thecatfan1 2/23/2011 5:45:39 PM(UTC)
Maytag LAT5005AAE has new Lid Switch assembly but fuse continues to blow, what next? (Washer Repair)
by hankshiggs 2/1/2011 11:35:15 AM(UTC)
Replaced defrost thermostat, what next? (Refrigerator & Freezer Repair)
by jesus freak 7/16/2010 7:53:25 PM(UTC)
What Next? (Oven Repair (including Ranges and Cooktops))
by Pastor Ken 7/15/2010 12:47:06 PM(UTC)
Maytag washer drain unclogged, what next? (Washer Repair)
by L. Caldwell 6/10/2010 9:12:22 PM(UTC)
What next? (Washer Repair)
by AmanaLWM353W 6/8/2010 11:26:52 AM(UTC)
Overload, Relay, Capacitor Replaced What Next? (Refrigerator & Freezer Repair)
by lrich002 11/16/2009 2:56:48 PM(UTC)
