tomsteven
#1 Posted : Monday, October 19, 2009 6:37:37 AM(UTC)
tomsteven
I have condensation forming on the frame of the refrigerator along the door frame. The condensation builds and evenutally falls on to the floor. I have already replaced the gaskets on both the freezer and refrigertor doors, turned the moisture switch to the on position, turned down the temperature, all to no avail. Any thing else I should try?
Frank / APP Team
#2 Posted : Monday, October 19, 2009 11:29:12 AM(UTC)
Frank / APP Team
There are heaters that are behind the breaker strips around the doors. GE calls them mullion heaters. They are probably bad. Bad news it appears that they are discontinued.
tomsteven
#3 Posted : Monday, October 19, 2009 1:18:44 PM(UTC)
tomsteven
Thanks for your response. I see them on the schematic that you have online. Is it difficult to remove the breaker strips around the door to check and make sure the connection is okay?
Frank / APP Team
#4 Posted : Tuesday, October 20, 2009 11:16:22 AM(UTC)
Frank / APP Team
The breaker strips will pry away from where they meet the cabinet. A thin bladed scewdriver will help. It can be tough doing it without scratching the paint on the cabinet. You will just need to be careful or you can run a piece of duct tape down the edge to help protect it.
Those heaters were common to fail. They would burn in half.
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 6/16/2022 10:57:08 AM(UTC)
Condensation PSS26SGPA SS (Refrigerator & Freezer Repair)
by B_Moon 1/23/2022 11:06:36 AM(UTC)
GE Refrigerator Flapper Condensation Buildup (Refrigerator & Freezer Repair)
by larsnilsen 5/10/2021 4:16:43 AM(UTC)
Ice dispenser door seal condensation (Refrigerator & Freezer Repair)
by JoePilot@sprynet.com 10/28/2012 5:14:07 PM(UTC)
Condensation on inside of dryer door (Dryer Repair)
by TexAg156 7/29/2012 6:28:27 AM(UTC)
Condensation problem - is it un-fixable? (Refrigerator & Freezer Repair)
by kevin_bkt 6/21/2012 7:46:44 AM(UTC)
Condensation on outside of ice chute flap.. (Refrigerator & Freezer Repair)
by FDAR 2/12/2012 8:52:30 AM(UTC)
Cannot connect condensation tube to new detergent dispenser (Dishwasher Repair)
by davidlin 9/2/2011 1:53:34 PM(UTC)
Refrigerator leaks condensation onto the floor (Refrigerator & Freezer Repair)
by david51 8/5/2011 3:59:14 AM(UTC)
Condensation/water inside refrigator (Refrigerator & Freezer Repair)
by LJ Franklin 7/12/2011 7:29:49 PM(UTC)
Bosch Axxis Condensation Dryer (Dryer Repair)
by eamiller11 10/20/2010 9:27:01 AM(UTC)
Condensation on back side of Refig/Freezer (Refrigerator & Freezer Repair)
by clintvic 9/29/2010 5:07:07 PM(UTC)
Removing condensation vent from soap dispensor (Dishwasher Repair)
by Mongillo 9/13/2010 11:53:46 AM(UTC)
Freezer condensation (Refrigerator & Freezer Repair)
by drip 7/5/2010 6:21:21 PM(UTC)
Excessive condensation in refrigerator (Refrigerator & Freezer Repair)
by conan646 3/10/2010 8:18:33 AM(UTC)
