Amiji
#1 Posted : Monday, September 14, 2009 8:52:34 AM(UTC)
Amiji
The tab on the ice dispenser door, which hold the spring pin is broken. Will the ice dispenser kit fix it as the broken tab seems to be on the housing itself.
kpossible33
#2 Posted : Saturday, October 3, 2009 3:19:22 PM(UTC)
kpossible33
I have had same problem. looks like dispenser housing must be replaced, anybody know where i can get one? parts list indicates no part number and not serviced.
Dispenser front parts replacement parts for WHIRLPOOL ED5LHEXTD00 | AppliancePartsPros.com
Number 1.
can anyone assist?
Thanks.
Amiji
#3 Posted : Saturday, October 3, 2009 3:50:47 PM(UTC)
Amiji
Number 1.
can anyone assist?
Thanks.
Yes, you would have to replace the housing and that is not available. The only option i got from Whirlpool was to buy a new door which would cost $600.00 +. Not worth buying a Whirlpool again !!
AIMANNY
#4 Posted : Saturday, October 3, 2009 4:04:30 PM(UTC)
AIMANNY
the ice door kit is avbl that fix is free call wirlpool
Amiji
#5 Posted : Saturday, October 3, 2009 4:53:54 PM(UTC)
Amiji
The kit will not fix the problem as it is the housing part which gets broken. It is poor designing!
SUPERTECH5
#6 Posted : Saturday, October 17, 2009 10:19:06 AM(UTC)
SUPERTECH5
I had the same problem and I fixed it my self. Just take control panel off, then unplug and unsnap white cover lift it and get out of the way. Then you will need help, somebody to hold spring loaded shutter pin in place. Slide pin as far to the right as possible. Then take 2 small galvanized drywall screws and 1 small washer. Install first screw with washer under pin making sure it does not interfear with any moving parts screw it in as tight as possible, then install other screw on top of the pin, that will hold pin in place and I guarantee you will never have a problem with the ice shutter again. Let me know how it goes.
Amiji
#7 Posted : Saturday, October 17, 2009 10:45:17 AM(UTC)
Amiji
Thanks! will give it a try but for now I have already improvised by sticking the broken bit with epoxy after removing the the dispenser door and all. I let the epoxy dry for a few days and replaced everything back. Till now the spring holds on becuase I put a fat layer of expoxy . Lets see for how long... ! :)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Broken pin tab on ice dispenser door (Refrigerator & Freezer Repair)
by SteveMG 11/10/2014 9:04:48 AM(UTC)
Ice dispenser door seal condensation (Refrigerator & Freezer Repair)
by JoePilot@sprynet.com 10/28/2012 5:14:07 PM(UTC)
Kenmore ice dispenser door delay not working (Refrigerator & Freezer Repair)
by Jridgell 4/18/2012 11:50:16 AM(UTC)
Ice dispenser door leaking air (Refrigerator & Freezer Repair)
by Harvey12 2/29/2012 5:31:34 PM(UTC)
Whirlpool Ice dispenser door not working (Refrigerator & Freezer Repair)
by commo 2/9/2011 9:25:33 PM(UTC)
Ice dispenser door won't stay closed (Refrigerator & Freezer Repair)
by rdbartow@yahoo.com 1/29/2011 6:14:17 AM(UTC)
Just installed new solenoidbut ice dispenser door will not close (Refrigerator & Freezer Repair)
by johnmazzone 7/25/2010 10:55:29 AM(UTC)
Broken ice dispenser door (Refrigerator & Freezer Repair)
by fbomb 2/1/2010 4:24:08 PM(UTC)
Removal of Ice Dispenser Door (Refrigerator & Freezer Repair)
by gadfly101@gmail.com 9/22/2009 11:35:16 AM(UTC)
Whirlpool ice dispenser door broken (Refrigerator & Freezer Repair)
by Mwis 5/6/2009 6:30:39 PM(UTC)
Ice dispenser door not closing (Refrigerator & Freezer Repair)
by kennit828 9/29/2008 4:02:09 PM(UTC)
