pete breeden
#1 Posted : Sunday, October 4, 2009 11:01:38 AM(UTC)
pete breeden
My dishwasher runs about 3-5mins then it stops and has a flashing PF. Theres still water in the bottom of dishwasher as well. about 1-2 inches. I pulled out and checked the drain and pump. they seem fine. What could be causing this. Thanks
#2 Posted : Sunday, October 4, 2009 11:32:27 AM(UTC)
Here is your tech sheet
http://manuals.frigidaire.com/p...Kinston/154718601_EN.pdf
PF is power failure so it could be a loose connection somewhere.
First place to check would be the wire nuts if the unit is hard wired into the house wiring.
Could also be a door switch or the latch.
Frustrated (Microwave Repair)
by tryagain 10/27/2012 12:32:47 PM(UTC)
GE Profile Defrost Issue - Very Frustrated (Refrigerator & Freezer Repair)
by jaypp1 8/18/2012 7:20:53 AM(UTC)
Frustrated Diy'er (Dryer Repair)
by dstoliby 1/13/2012 11:03:39 AM(UTC)
Frustrated washer repair (Washer Repair)
by willowtree 6/6/2011 8:15:09 AM(UTC)
Very frustrated! (Oven Repair (including Ranges and Cooktops))
by nculver 1/23/2011 8:33:02 AM(UTC)
Also frustrated (Oven Repair (including Ranges and Cooktops))
by Les Coil 9/23/2010 11:38:40 AM(UTC)
by Les Coil 9/23/2010 11:33:11 AM(UTC)
Help! Flashing Lights-dead Dishwasher?-signed Frustrated Mom (Dishwasher Repair)
by manualplease 7/11/2010 12:46:53 PM(UTC)
confused and frustrated (Dishwasher Repair)
by Florenrose 5/8/2010 3:19:00 PM(UTC)
Frustrated with Frigidaire Dishwasher (Dishwasher Repair)
by afpd604 11/21/2009 8:25:07 AM(UTC)
Frustrated- Won't finish cycle (Washer Repair)
by Jack-99 10/17/2009 8:14:55 PM(UTC)
Frustrated! (Washer Repair)
by boxermama 2/13/2009 7:57:34 AM(UTC)
