Frigidaire Dishwasher FDBB4365FS3, All lights flashing and an ER message on screen. I went through the service test sequence and it told me that the rinse aid was bad. Replaced rinse aid. Worked in service test until filled then got error and flashing again. Replaced control board and rinse aid again. Same result as above...AGAIN! Thinking of replacing console panel now and rinsed again. Lucky parts have lifetime guarantee!! Will this solve my problem? I was also wondering if wires to rinse aid level switch are reversed. Which color should be towards me with the door closed and the front panel off? Thank You :)
Replaced control console and rinse aid this solved all my problems. Console part came with a error code tip sheet. Please see my other post(s) that have it attached...:D
Hello afpd604...I have a frigidaire PLD3460RDC1 with the flashing ER as well as all the other orange lights. I was told to replace the control unit, but now that I read your post, I see I may have to replace the rinse aid as well. Do you suggest I try the control first? Thanks, Ed
