juansalazar_13
#1 Posted : Wednesday, September 30, 2009 7:53:12 AM(UTC)
juansalazar_13
how to install four wire power cord for use in a mobil home
sidfink43
#2 Posted : Wednesday, September 30, 2009 5:09:31 PM(UTC)
sidfink43
With four wires the green ground wire from the cord is connected to the dryer frame. The green ground wire in the dryer grounds to the frame, which then grounds everything thorugh the cord. The white wire goes in the middle of the three wire connections on the connection block, the others on the ends.
Here is a brief instruction and photo.
http://www.applianceaid.com/general.html#3to4
#3 Posted : Thursday, October 1, 2009 2:06:10 AM(UTC)
Remember to remove the wire that goes from the center terminal of the block to the frame. This is only used in 3 wire hook-ups.
The green (earth ground) of your 4 wire will now hook to the frame and the white (Neutral) will hook to the center terminal.
How to wire a 4 prong power cord to an older dryer (Dryer Repair)
by hochoi 7/15/2018 3:00:38 PM(UTC)
Weird power cord behavior -- dangerous? (Refrigerator & Freezer Repair)
by snakestu 2/25/2016 4:45:56 PM(UTC)
Kenmore Dryer - Changed Power Cord & Now Noisy? (Dryer Repair)
by kjcristillo 10/2/2015 4:31:14 PM(UTC)
Need to replace power cord (Oven Repair (including Ranges and Cooktops))
by cwelchj@gmail.com 4/18/2015 4:28:39 AM(UTC)
Whirlpool dryer motor comes on when I plug in power cord (Dryer Repair)
by Nick from Detroit 8/29/2014 3:38:09 PM(UTC)
Power Cord (Dryer Repair)
by lenius1 9/30/2013 8:06:14 AM(UTC)
Power cord replacement A/C fell from window (Heating, Ventilation, and Air Conditioning (HVAC))
by Johnfliesagain 8/19/2013 6:37:53 PM(UTC)
by rdedeaux 9/27/2012 3:23:46 PM(UTC)
power cord (Dishwasher Repair)
by brent32tn 9/4/2012 3:29:15 PM(UTC)
replacing power cord (Trash Compactor Repair)
by Derrell 9/4/2012 3:10:23 PM(UTC)
bosch power cord (Dishwasher Repair)
by jcouzzi 8/9/2012 7:43:24 AM(UTC)
Change a power cord in a Samsung Refrigerator (Refrigerator & Freezer Repair)
by rickim757 1/11/2012 7:27:22 PM(UTC)
power cord had short I fixed the cord and now nothing (Dryer Repair)
by tlh18 11/1/2011 5:10:18 PM(UTC)
replacing Kenmore Washer power cord to ground it, change angle of cord (Washer Repair)
by maddy 6/15/2011 10:46:04 AM(UTC)
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? (Washer Repair)
by maddy 6/15/2011 9:11:07 AM(UTC)
