rdedeaux
#1 Posted : Thursday, September 27, 2012 3:23:46 PM(UTC)
rdedeaux
Had To Change The Power Cord From A Four Prong To A Three Prong And Now The Dryer Is'nt Heating. What Might My Problem Be?
#2 Posted : Friday, September 28, 2012 1:34:46 AM(UTC)
You will have to double check how you wired the unit.
Here is the install sheet for the unnit.
http://products.geapplia...DF&Name=31-15475.pdf
If the wiring is OK then you will have to check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
How to wire a 4 prong power cord to an older dryer (Dryer Repair)
by hochoi 7/15/2018 3:00:38 PM(UTC)
Weird power cord behavior -- dangerous? (Refrigerator & Freezer Repair)
by snakestu 2/25/2016 4:45:56 PM(UTC)
Kenmore Dryer - Changed Power Cord & Now Noisy? (Dryer Repair)
by kjcristillo 10/2/2015 4:31:14 PM(UTC)
Need to replace power cord (Oven Repair (including Ranges and Cooktops))
by cwelchj@gmail.com 4/18/2015 4:28:39 AM(UTC)
Whirlpool dryer motor comes on when I plug in power cord (Dryer Repair)
by Nick from Detroit 8/29/2014 3:38:09 PM(UTC)
Power Cord (Dryer Repair)
by lenius1 9/30/2013 8:06:14 AM(UTC)
Power cord replacement A/C fell from window (Heating, Ventilation, and Air Conditioning (HVAC))
by Johnfliesagain 8/19/2013 6:37:53 PM(UTC)
power cord (Dishwasher Repair)
by brent32tn 9/4/2012 3:29:15 PM(UTC)
replacing power cord (Trash Compactor Repair)
by Derrell 9/4/2012 3:10:23 PM(UTC)
bosch power cord (Dishwasher Repair)
by jcouzzi 8/9/2012 7:43:24 AM(UTC)
Change a power cord in a Samsung Refrigerator (Refrigerator & Freezer Repair)
by rickim757 1/11/2012 7:27:22 PM(UTC)
power cord had short I fixed the cord and now nothing (Dryer Repair)
by tlh18 11/1/2011 5:10:18 PM(UTC)
replacing Kenmore Washer power cord to ground it, change angle of cord (Washer Repair)
by maddy 6/15/2011 10:46:04 AM(UTC)
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? (Washer Repair)
by maddy 6/15/2011 9:11:07 AM(UTC)
Whirlpool Duet Power Cord (Washer Repair)
by Onedodal 6/15/2011 8:47:26 AM(UTC)
