cmb
#1 Posted : Tuesday, September 22, 2009 12:48:00 PM(UTC)
cmb
When you put the oven on Bake it will not heat over 200 degrees. Before when you go to bake it would automatically show 350 Degrees. But doesnt do that anymore at all.The element works fine on broil.
#2 Posted : Wednesday, September 23, 2009 12:30:23 PM(UTC)
Remove the oven floor and inspect the Bake heating element.
If there is no visible damages then pull the range out of the wall, remove the rear panel and inspect the wires to the heating element.
Remove the wires from the heating element and check the element for continuity.
Check for 240 VAC between the heating element wires while the control calls for Bake.
Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PER5750LAW | AppliancePartsPros.com
cmb
#3 Posted : Thursday, September 24, 2009 6:29:06 PM(UTC)
cmb
Yes thank you the element is bad
#4 Posted : Thursday, September 24, 2009 9:55:25 PM(UTC)
The Bake element Part number: AP4101290
cmb
#5 Posted : Friday, September 25, 2009 3:24:25 AM(UTC)
cmb
Thank you gene for your help, I am going to try and pick one up local at ************** appliance in tampa. If i need to order i will have you order it for me.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 5/21/2024 3:00:41 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
