RobinAlice
#1 Posted : Sunday, September 20, 2009 7:47:35 AM(UTC)
RobinAlice
dryer stops running after 5 minutes and circuit breaker is tripped. When problem first started dryer would run for 15-20 minutes before tripping circuit breaker. Is it the dryer, receptacle, cord or circuit breaker?:eek:
glen65
#2 Posted : Sunday, September 20, 2009 9:15:10 AM(UTC)
glen65
Does the dryer seem to work ok while running?
RobinAlice
#3 Posted : Sunday, September 20, 2009 9:20:24 AM(UTC)
RobinAlice
Yes, although I just tried it on a different heat setting with only 1 towel in it and the time seemed even shorter-only ran for 2 1/2 minutes. If I am reading articles correctly, the dryer should be running on 2 different circuits. In my case, only 1 circuit is tripping.
glen65
#4 Posted : Monday, September 21, 2009 12:14:32 PM(UTC)
glen65
A current test is going to need to be done with an amp meter
to find out how much amperage this unit is drawing from the outlet. Typically an electric dryer pulls about 24-26 amps from (what should be) its 30 amp
breaker. If the amperage checks OK then to you have a problem
with your service, maybe a bad circuit breaker.
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Dryer stops running when I release the push to start button (Dryer Repair)
by Guest 6/22/2022 9:57:15 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
Frigidaire dryer stops running (Dryer Repair)
by Fritzfarm 12/22/2011 9:03:34 AM(UTC)
Dryer stops running after a while (Dryer Repair)
by darcher007 1/16/2011 3:05:41 PM(UTC)
by pstulken 12/22/2010 2:47:11 PM(UTC)
Dryer stops running after 10minutes (Dryer Repair)
by Jimmyz2011 12/20/2010 12:35:26 PM(UTC)
dryer stops running after 20 seconds (Dryer Repair)
by Glen Hoh 10/14/2010 6:30:33 AM(UTC)
Dryer stops running before timer cycle ends (Dryer Repair)
by fascamaro 2/6/2010 3:56:45 AM(UTC)
Dryer stops running (Dryer Repair)
by Ricky50 8/19/2009 7:15:58 PM(UTC)
Dryer stops running on heat settings (Dryer Repair)
by tld61672 4/12/2009 4:30:39 AM(UTC)
Roper dryer stops running (Dryer Repair)
by NcTarHeel704 3/1/2009 9:51:11 AM(UTC)
by den123 11/9/2008 6:50:33 AM(UTC)
Dryer stops running after letting off the Start button (Dryer Repair)
by Andy 7/27/2007 8:13:13 AM(UTC)
