makrani12
#1 Posted : Monday, September 14, 2009 8:43:47 AM(UTC)
makrani12
The dryer wont turn on. I unpluged and pluged it back on, control panel lights up, and made sure door closed and press start/pause button, nothing happens.
Help
glen65
#2 Posted : Monday, September 14, 2009 9:33:06 AM(UTC)
glen65
Help
This is assuming that the voltage at your outlet is ok.
Something I would want to check are the thermal fuses.
There is one on the where the heating element is located
and one in the blower housing area. Now keep in mind if this
is the culprit there is a "reason why" one of them failed. The one by the
element usually fails because either the heat element coil is shorted
to its metal case or the high limit thermostat is not cycling out
properly. The one in the blower housing can go out because of an airflow issue maybe even due to a striped blower wheel. Although an airflow issue can cause either one of then to go out. You also need to closely examine the vent especially before putting the dryer back in service after its been
repaired.
(With the dryer unplugged) These fuses would have to be checked using an ohmmeter.
If these both check ok then other electrical testing on the dryer will have to be done.
#3 Posted : Monday, September 14, 2009 9:37:15 AM(UTC)
Motor drive replacement parts for MAYTAG MDE5500AYQ | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
If you have the correct voltage 240 volts from L1 to L2 and 120 volts from L1 to Neutral and L2 to Neutral then odds are high that one of the thermal fuses has blown. Item 11 in the Heater section and Item 10 in the Motor section.
Best to unplug the unit and check them with a meter.
If a thermal fuse is blown be sure to give the interior a good cleaning including the blower wheel. Also clean and check your vent system.
makrani12
#4 Posted : Saturday, September 19, 2009 2:22:25 PM(UTC)
makrani12
Thanks for replying back.
I havent tried anything yet but i really appreciate.
I also noticed that sometimes the dryer console showed 18 for no reason. So i unplugged it and plug it back and would go away for couple of days. So is that a code or just a coincedence.
Please let me know.
Tony
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
