LSUKixAss1
#1 Posted : Saturday, January 19, 2008 11:15:51 AM(UTC)
LSUKixAss1
My washing machine has started overfilling and will not begin the wash cycle. Any ideas what may be causing this? In order to drain the machine, I put it in the spin cycle. When I opened the top to check on the progress, the tub stopped spinning but made a screeching noise when it came to a stop. Not sure if this is normal or not, or if the two problems are related at all. Any help would be appreciated. The tub has a lot of "play" in it (moves from side to side very easily).
#2 Posted : Saturday, January 19, 2008 6:35:13 PM(UTC)
Open the control panel and check for a loose pressure (clear plastic) hose which should be connected to the water level switch.
If the pressure hose is in place then the water level switch has to be replaced.
Some noise at the stop time is normal. It's coming from the breaks.
- The part number for the water level switch is AP246906
Here are the break down diagrams for the Admiral washer Model LNC6760A71
LSUKixAss1
#3 Posted : Wednesday, January 23, 2008 5:36:53 PM(UTC)
LSUKixAss1
OK, I bought the AP246906 water switch. But is has different labeling on the wire connectors than the original one on the washer.
Original one has three connections numbered 11,14 and 12. Orange wire attached to #12, blue wire attached to #14 and gray wire attached to #11.
This new switch has three connectors as well, but they are numbered 1, 2 and 3. How do I know what color wire goes to what number?
washer overfills (Washer Repair)
by slugo2 1/29/2015 3:35:31 PM(UTC)
GE washer overfills (Washer Repair)
by Shad Blewett 11/9/2013 6:07:54 PM(UTC)
Washer Overfills (Washer Repair)
by mikie67 8/28/2013 7:28:09 PM(UTC)
Washer overfills and will not spin (Washer Repair)
by HerschelD 6/18/2013 4:28:09 PM(UTC)
Washer overfills (Washer Repair)
by Auburn 6/2/2013 9:31:33 AM(UTC)
washer overfills and also turns its self on (Washer Repair)
by scamden40 1/21/2013 11:05:54 PM(UTC)
washer overfills , not sure why (Washer Repair)
by fhorta 1/12/2013 10:05:09 AM(UTC)
GE Washer overfills (Washer Repair)
by sprankles2012 10/5/2012 5:03:01 PM(UTC)
Maytag washer overfills (Washer Repair)
by UmuttaU 9/27/2012 5:16:35 AM(UTC)
Washer overfills the tub and floods the floor (Washer Repair)
by John22307 7/14/2012 7:00:20 AM(UTC)
Maytag washer overfills the water (Washer Repair)
by jaz6420 3/26/2012 5:13:37 PM(UTC)
RCA washer overfills on soak cycle (Washer Repair)
by Skynard213 8/17/2011 6:14:42 PM(UTC)
Dishwasher overfills occasionally (Dishwasher Repair)
by jerry80234 3/12/2011 3:42:19 PM(UTC)
by lanedowns 1/16/2011 7:49:23 AM(UTC)
ge washer overfills (Washer Repair)
by shorthorn 5/28/2010 7:15:54 PM(UTC)
