sprankles2012
#1 Posted : Friday, October 5, 2012 5:03:01 PM(UTC)
sprankles2012
I have a washer that won't stop filling and floods. I checked the water level switch hose, it had some gunk in it which I removed. I also clean the piece that it attaches to on the tub. I started the washer and blew into the tube and the air pressure tripped the switch and it stopped filling, but when I attach it to the tub it doesn't trip the switch. I should also mention that it has been intermittently been leaving the clothes wet after the spin cycle. The tub won't be full, but the clothes will be heavy with water and there has been a moldy smell. It has been a great washer until the past few weeks.
Thanks for any help.
-JP
sidfink43
#2 Posted : Sunday, October 7, 2012 5:55:28 PM(UTC)
sidfink43
You did a good job of diagnosing the problem.
For some reason your tube is leaking, there may be a hole or there may be a problem where it attaches. If the tube is ok the switch may be bad. That is it will trip when you blow hard, but not with the pressure from the tube.
sprankles2012
#3 Posted : Sunday, October 7, 2012 6:09:38 PM(UTC)
sprankles2012
Thanks for responding Sidfink. I thought that might be the case, so I actually did replaced the hose and it still didn't work. Finally, I ended up blowing on the other end of the hose to see if maybe there was something clogged up in the little box on the side of the tub that the tube for the air switch attaches to and that did it. It now works just fine. Thanks again for getting back with me and this is a great resource.
-JP
GE washer overfills (Washer Repair)
by Shad Blewett 11/9/2013 6:07:54 PM(UTC)
ge washer overfills (Washer Repair)
by shorthorn 5/28/2010 7:15:54 PM(UTC)
GE Washer Overfills and does not start Washing (Washer Repair)
by mopar73 11/3/2009 5:09:50 PM(UTC)
