taz1
#1 Posted : Monday, September 14, 2009 9:45:10 PM(UTC)
taz1
My dryer will not heat. I need to know what does the heating element looks like when I open take the back off.
#2 Posted : Tuesday, September 15, 2009 3:17:20 AM(UTC)
Replacement parts for WHIRLPOOL REX6634RQ1 | AppliancePartsPros.com
See Item 17 in the Bulkhead section
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
I am assuming that the drum rotates and you just do not get heat!!
NOTE: Be sure to unplug the unit when opening it up and working on it, 240 volts is lethal!!!
Does the timer advance in timed dry mode?
Both the timer and the heater require 240 volts.
If not try turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter.
If the heater measures OK (10 ohms approximately) the next possible cause is the thermal cutout Item 6 in the Bulkhead section (0 ohms at room temperature)
If the thermal cutoff is blown be sure to give the interior including the blower wheel a good cleaning. Also clean/check your vent system.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
