Stormtrooper9
#1 Posted : Sunday, August 12, 2007 6:34:23 AM(UTC)
Stormtrooper9
Dishwasher is washing good, but there is water left in the tub after all cycles are completed. Drain hose couldn't be plugged as the water drains throughout the cycle. HELPPPPPPPPPPPPPPPP:(
jdman
#2 Posted : Sunday, August 12, 2007 7:05:28 AM(UTC)
jdman
Do you have an airgap? If not, checkthe drain hose. Does it have a loop before it connects to drain pipe? If no air gap, drain hose from unit must go up to the underside of counter then down to where it connect to the drain pipe or disposal. Good Luck
ApplianceJunk
#3 Posted : Sunday, August 12, 2007 7:24:15 AM(UTC)
ApplianceJunk
The drain hose could be partially plugged.
The dishwasher only drains out for so long. If it is partially plugged it will not be able to drain the water fast enough in the amount of time it has to run in the drain cycle.
Stormtrooper9
#4 Posted : Sunday, August 12, 2007 4:29:05 PM(UTC)
Stormtrooper9
It has been working great for 4 years and out of the blue it starts this. I took it out from under the counter this morning and ran a quick wash and it worked find and later a normal wash. I did it again after dinner and the water is again standing in the bottom. Sounds like a Repairman, was hoping it wouldn;t come to that.
Stormtrooper9
#5 Posted : Sunday, August 12, 2007 6:52:50 PM(UTC)
Stormtrooper9
Dishwasher has standing water (Dishwasher Repair)
by brokendishwasherbro 10/31/2016 7:04:01 AM(UTC)
standing water in dishwasher (Dishwasher Repair)
by kingeddiej 10/10/2015 5:07:05 AM(UTC)
by keegers 8/13/2013 1:19:12 PM(UTC)
Standing water inside GE Profile Dishwasher (Dishwasher Repair)
by cowboyfan41565 10/7/2012 1:49:40 PM(UTC)
Standing water in Maytag dishwasher (Dishwasher Repair)
by Macguy59 7/17/2012 3:41:03 PM(UTC)
GE Dishwasher - Standing water (abt an inch or more) left after draining. (Dishwasher Repair)
by hughesdc 1/17/2012 3:28:14 PM(UTC)
GE Nautilus won't drain - standing water (Dishwasher Repair)
by cherylbland 1/6/2012 6:22:24 AM(UTC)
Whirlpool quiet partner2, standing water,wont come on (Dishwasher Repair)
by egails 7/5/2011 4:51:07 PM(UTC)
dishwasher standing water (Dishwasher Repair)
by kschmeck 5/28/2011 7:47:30 AM(UTC)
standing water after wash cycle.. (Dishwasher Repair)
by steeve 12/29/2010 7:34:09 AM(UTC)
standing water in bottom of tub (Dishwasher Repair)
by rico824 9/1/2010 9:57:25 AM(UTC)
small amount of standing water in bottom - normal? blockage? (Dishwasher Repair)
by ACR928 7/3/2010 10:03:20 AM(UTC)
BOSCH SHU5305UC - Standing water in bottom of washer after cycle completes (Dishwasher Repair)
by ladieu 3/28/2010 3:53:55 PM(UTC)
Kenmore HE4t standing water inside after sitting (Washer Repair)
by briant97 3/24/2010 4:02:17 PM(UTC)
by tmr 2/27/2010 9:17:22 AM(UTC)
