Macguy59
#1 Posted : Tuesday, July 17, 2012 3:41:03 PM(UTC)
Macguy59
Maytag dishwasher model MDB5100AWW
After sitting empty for a day or 2 , the bottom fills with a half inch of dirty looking water. We had a repair man out and he replaced the water valve but it did not fix the problem. The dual kitchen sink does have a disposal on one side. Drain line issue ? Other possible causes ?
#2 Posted : Wednesday, July 18, 2012 2:50:30 AM(UTC)
[COLOR="Blue"]Drain line issue ? [/COLOR]
Since it is dirty water that would be my guess.
Although not for a Maytag here is a good install sheet.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
Check that the drain is looped high enough.
