I tried to do some baking. The oven heats up then shuts down. I can turn the oven on again but if its hot it turns off after 1 minute
Originally Posted by: DakotaandJack12 I tried to do some baking. The oven heats up then shuts down. I can turn the oven on again but if its hot it turns off after 1 minute I'd tryu looking at the oven temp sensor. Do it measure out correct resistance?
I'm going to do that but it's very difficult. I have to pull the oven AND attached microwave out of the wall and onto the floor in order to remove the sensor to check the resistance
