TomCassisa
#1 Posted : Saturday, September 5, 2009 12:04:59 PM(UTC)
TomCassisa
My Whirlpool Dryer heats up only briefly after first turning it on.
We had a build up of excessive lint and a small fire occurred that scorched the lint built up on the very bottom of the appliance . No wires or other parts appeared to be visibly damaged.
After cleaning the excessive and scorched lint and trying to restart the unit, I found the heating element gets red when first turning the unit on, then immediately goes out. I figure the T-stat, hi - limit (Part Number: AP3084674 made by WHIRLPOOL) could have been damaged by the heat when the excessive lint briefly ignited.
Is this the part I should try to replace 1st or should I try something else?
sidfink43
#2 Posted : Monday, September 7, 2009 6:38:19 AM(UTC)
sidfink43
The hi limit thermostat does not reset itself, so if it is bad, it stays bad.
I would try the cycling thermostat,
Part number: AP3045874
This is coming up as a gas model, if that is the case you will need to check out and probably replace the gas components.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
