Ok i have gotten the module to do a semi-successful harvest - the tray didnt fill. (still no water)
I successfully jumped the t&H prts on the module the teeth started moving - powered off before the 10 position undid the jumper. plugged the fridge back in waited about 10 seconds opened freezer door optic light solid for about 5 seconds then off however still no water to the cube tray this morning i looked and the teeth are still moving (there in a different spot than last night when i went to bed)
Not sure were to go from here? is it the temp sensor not thinking the freezer is cold enough? is it the water inlet valve on the back of the fridge, even though i get water thru the indoor dispenser?
Thanks for All the Help so far
Swap the wires on the water valve solenoids and push the water dispenser lever. Open the freezer door and check if there is water in the ice maker. If the answer is Yes, then the water valve is bad.
Originally Posted by: Gene  Swap the wires on the water valve solenoids and push the water dispenser lever. Open the freezer door and check if there is water in the ice maker. If the answer is Yes, then the water valve is bad.
Gene. Thanks ill give it a shot this weekend!!
I'm new to this forum, and not very familiar with how it works. I have a Kenmore(Whirlpool) side by side refrigerator with ice bin in the door. The ice maker would not turn off, and the electric eye was not working. I ordered the replacement two piece circuit boards that are shown in this forum, and replaced the boards. However, while waiting on the parts to arrive, the ice maker stopped making ice. Now that I have replaced the boards, the LED lights blink like they should, but no ice is being made. Is there a way to trigger the icemaker to cycle? I'm thinking maybe it got hung up some how when the unit wouldn't turn off. I did run a blow dryer on it in an attempt to melt any ice that might be clogging the mechanism up.
i looked at the valve and there are 2 connectors to the valve - i assume 1 for indoor the other for the freezer when i take the connectors off though they are different sizes so i cannot simmply switch them- also i thought about switching the water tubes but of course they are different sizes also. Any ideas?
Originally Posted by: Cougar  I'm new to this forum, and not very familiar with how it works. I have a Kenmore(Whirlpool) side by side refrigerator with ice bin in the door. The ice maker would not turn off, and the electric eye was not working. I ordered the replacement two piece circuit boards that are shown in this forum, and replaced the boards. However, while waiting on the parts to arrive, the ice maker stopped making ice. Now that I have replaced the boards, the LED lights blink like they should, but no ice is being made. Is there a way to trigger the icemaker to cycle? I'm thinking maybe it got hung up some how when the unit wouldn't turn off. I did run a blow dryer on it in an attempt to melt any ice that might be clogging the mechanism up. Check the water feeding tube into the ice maker for an ice inside. Perform the ice maker troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...-maker-quit-working.html and post the results. Post the complete model number of the refrigerator. Gene.
Originally Posted by: deadpool328  ...when i take the connectors off though they are different sizes so i cannot simmply switch them... You can try to use two pieces of insulated wire to make such connection between the wire plugs and the valve terminals. Be careful not to cross them. Gene. P.S. The solenoid for the ice maker has 1/4" plastic tube connected.
Originally Posted by: deadpool328  I have a pdf copy of the service manual for my Whirlpool icemaker i cannot attach it for whatever reason - i get an invalid page error message or something. Id be happy to get it to you but im not sure how.
im going to be checking my ice maker tonight to see if im getting power to the module. Are u able to email pdf file, I need it. Thanks my email: mkansari03@yahoo.com:D
