2 Pages<12
deadpool328
#11 Posted : Thursday, September 3, 2009 7:00:28 AM(UTC)
deadpool328
Ok i have gotten the module to do a semi-successful harvest - the tray didnt fill. (still no water)
I successfully
jumped the t&H prts on the module
the teeth started moving -
powered off before the 10 position
undid the jumper.
plugged the fridge back in
waited about 10 seconds
opened freezer door
optic light solid for about 5 seconds then off
however still no water to the cube tray
this morning i looked and the teeth are still moving (there in a different spot than last night when i went to bed)
Not sure were to go from here?
is it the temp sensor not thinking the freezer is cold enough?
is it the water inlet valve on the back of the fridge, even though i get water thru the indoor dispenser?
Thanks for All the Help so far
#12 Posted : Thursday, September 3, 2009 6:46:13 PM(UTC)
Swap the wires on the water valve solenoids and push the water dispenser lever. Open the freezer door and check if there is water in the ice maker. If the answer is Yes, then the water valve is bad.
deadpool328
#13 Posted : Friday, September 4, 2009 5:22:37 AM(UTC)
deadpool328
Thanks ill give it a shot this weekend!!
Cougar
#14 Posted : Friday, September 4, 2009 5:48:41 AM(UTC)
Cougar
I'm new to this forum, and not very familiar with how it works. I have a Kenmore(Whirlpool) side by side refrigerator with ice bin in the door. The ice maker would not turn off, and the electric eye was not working. I ordered the replacement two piece circuit boards that are shown in this forum, and replaced the boards. However, while waiting on the parts to arrive, the ice maker stopped making ice. Now that I have replaced the boards, the LED lights blink like they should, but no ice is being made. Is there a way to trigger the icemaker to cycle? I'm thinking maybe it got hung up some how when the unit wouldn't turn off. I did run a blow dryer on it in an attempt to melt any ice that might be clogging the mechanism up.
deadpool328
#15 Posted : Saturday, September 5, 2009 6:07:40 AM(UTC)
deadpool328
i looked at the valve and there are 2 connectors to the valve -
i assume 1 for indoor the other for the freezer
when i take the connectors off though they are different sizes so i cannot simmply switch them- also i thought about switching the water tubes but of course they are different sizes also.
Any ideas?
#16 Posted : Saturday, September 5, 2009 1:41:46 PM(UTC)
Check the water feeding tube into the ice maker for an ice inside. Perform the ice maker troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...-maker-quit-working.html and post the results. Post the complete model number of the refrigerator.
#17 Posted : Saturday, September 5, 2009 1:45:36 PM(UTC)
Originally Posted by: deadpool328 Go to Quoted Post
...when i take the connectors off though they are different sizes so i cannot simmply switch them...
You can try to use two pieces of insulated wire to make such connection between the wire plugs and the valve terminals. Be careful not to cross them.
P.S. The solenoid for the ice maker has 1/4" plastic tube connected.
mkansari03
#18 Posted : Monday, June 28, 2010 12:02:31 PM(UTC)
mkansari03
I have a pdf copy of the service manual for my Whirlpool icemaker
i cannot attach it for whatever reason - i get an invalid page error message or something.
Id be happy to get it to you but im not sure how.
im going to be checking my ice maker tonight to see if im getting power to the module.
Are u able to email pdf file, I need it. Thanks
my email: mkansari03@yahoo.com:D
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 3/7/2023 12:03:25 PM(UTC)
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 9/19/2022 9:02:45 AM(UTC)
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 9/3/2021 10:14:18 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 5/8/2016 2:24:52 PM(UTC)
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 8/1/2015 9:44:31 AM(UTC)
by kidmims 7/25/2015 9:41:54 AM(UTC)
Ice Maker not making Ice. (Refrigerator & Freezer Repair)
by atticus1 6/11/2015 5:28:24 PM(UTC)
by gaff 11/13/2013 7:29:05 PM(UTC)
Ice maker Not making ice (Refrigerator & Freezer Repair)
by chavisfamily1234 11/2/2012 8:52:20 PM(UTC)
by cgoodwin 8/2/2012 11:07:55 AM(UTC)
by Guido 6/22/2012 9:40:34 AM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
2 Pages<12
