okiekw
#1 Posted : Sunday, January 20, 2008 7:25:29 PM(UTC)
okiekw
Oven won't heat, elements etc. check okay. Changed clock unit twice but still no heat. Please help.
kawfeeman
#2 Posted : Monday, January 21, 2008 4:51:39 AM(UTC)
kawfeeman
what voltage to you have to your bake element ? do you have 120vac at least to one leg of the element ?
okiekw
#3 Posted : Monday, January 21, 2008 5:29:35 AM(UTC)
okiekw
Yes getting 120, but not 220. Either both clock units are bad or I'm missing something.
kawfeeman
#4 Posted : Monday, January 21, 2008 6:03:39 AM(UTC)
kawfeeman
statistically unlikely both clocks are bad... need to figure out which wire is not giving you the other 120vac you need and follow it back to where it starts from ...
okiekw
#5 Posted : Monday, January 21, 2008 6:28:30 AM(UTC)
okiekw
Have done this, wires seem fine back to unit. When I hit bake unit clicks a couple of times, shows 100 degrees but does not heat.
Amana oven (insert) turns off (Oven Repair (including Ranges and Cooktops))
by Melodyportillo 12/29/2019 10:12:09 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
How to access amana oven door latch (Oven Repair (including Ranges and Cooktops))
by Handyguy1 9/30/2015 7:39:03 PM(UTC)
Amana oven not heating (Oven Repair (including Ranges and Cooktops))
by myrnarud 9/24/2014 7:15:11 PM(UTC)
Amana Oven/Range Fuse? (Oven Repair (including Ranges and Cooktops))
by sashko 3/20/2014 1:45:41 PM(UTC)
how do I replace relay board on amana oven (Oven Repair (including Ranges and Cooktops))
by ghappe 11/4/2013 11:30:31 AM(UTC)
Amana Oven Fails after Power Failure (Oven Repair (including Ranges and Cooktops))
by newatappliancerepair 2/4/2013 9:05:57 PM(UTC)
Amana Oven Problem (Oven Repair (including Ranges and Cooktops))
by JOHN S. 1/10/2013 5:50:09 PM(UTC)
Amana oven temp keeps climbing then display goes out (Oven Repair (including Ranges and Cooktops))
by Jovian66 12/26/2012 6:20:27 PM(UTC)
Amana oven smells of LP after oven is off (Oven Repair (including Ranges and Cooktops))
by m22214 11/13/2012 2:01:34 PM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
Amana oven won't heat properly (Oven Repair (including Ranges and Cooktops))
by azace 7/14/2012 1:24:16 PM(UTC)
Amana oven not getting hot? (Oven Repair (including Ranges and Cooktops))
by bipinsen 4/17/2012 8:40:47 AM(UTC)
Amana Oven Not Working (Oven Repair (including Ranges and Cooktops))
by brijets 12/20/2011 5:12:15 AM(UTC)
Amana Oven F9 error (Oven Repair (including Ranges and Cooktops))
by Creston 12/7/2011 5:56:40 AM(UTC)
