peak_az@yahoo.com
#1 Posted : Monday, August 6, 2007 4:43:45 PM(UTC)
peak_az@yahoo.com
the washer will not spin on a full load and only will on a very small load if you help the tub start spinning
peak_az@yahoo.com
#2 Posted : Monday, August 6, 2007 4:53:20 PM(UTC)
peak_az@yahoo.com
:confused:
#3 Posted : Monday, August 6, 2007 6:46:57 PM(UTC)
The first thing I would check is the drive block. In order to do it you have to remove the cabinet and the agitator.
Remove the tub ring unsnapping the tub ring tabs from the tub one at a time.
Next step is to remove the spanner nut. You can do it using a hummer and a screwdriver or you can buy a special spanner wrench . However, it is recommended to use the special spanner wrench to properly tighten the spanner nut at the end of the repair.
Carefully remove the basket by lifting straight up. Using a hummer, carefully tap up from the bottom of the drive block to remove.
Inspect the notches on the drive block and the tabs on the spin tube. If the notches on the drive block are worn out, replace the drive block.
Here is the video clip to help you: Washer Drive Block (part #389140) - How To Replace - YouTube
If the problem is worn out tabs on the spin tube there is more serious job because the spin tube is a part of the basket drive/brakes assembly and to replace it you have to remove the gear case (aka transmission). Let me know if you are going to do it and I'll help you.
Good luck.
[IMG]http://www.youtube.com/watch?feature=player_detailpage&v=lsgl6PSQwtc[/IMG]
[IMG]http://www.youtube.com/watch?v=lsgl6PSQwtc&feature=player_embedded[/IMG]
71trucklover
#4 Posted : Saturday, January 19, 2008 12:00:33 PM(UTC)
71trucklover
:confused:
I have the same problem did this fix it
#5 Posted : Saturday, January 19, 2008 2:49:11 PM(UTC)
If you find the spin basket is tight on the spin tube, then you probably have a failed clutch, just check.
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
Buzzing and not spinning (Washer Repair)
by sweetac100 11/22/2022 2:50:16 PM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Whirlpoool Duet not spinning clothes dry (Washer Repair)
by AdamsBT1 4/9/2022 6:03:49 AM(UTC)
Ge washer tub not spinning (Washer Repair)
by Rconner86 3/17/2022 7:32:41 PM(UTC)
Maytag MTW5770TQ) Draining but not spinning (Washer Repair)
by cj2874 2/6/2022 3:54:15 PM(UTC)
Whirlpool WTW4950xw0 not spinning, draining (Washer Repair)
by webdiva20 12/29/2021 10:43:20 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
