davidsonr379@aol.com
#1 Posted : Sunday, August 30, 2009 9:48:49 AM(UTC)
No heat , everything else seems to be ok.
Rick
sidfink43
#2 Posted : Monday, August 31, 2009 3:29:20 PM(UTC)
sidfink43
Tell what you checked and how you checked it to say that everything else is ok.
Also, does the machine run and not heat, or not run at all?
We really need as much info as is relevant to help you out here.
kayakcrzy
#3 Posted : Tuesday, September 1, 2009 4:43:16 AM(UTC)
kayakcrzy
Originally Posted by: davidsonr379@aol.com Go to Quoted Post
no heat , everything else seems to be ok.
rick
let me help you out here. this is a everyday problem with your dryer. unplug the dryer, and take the back off. it will either be the element is broken, or there is a thermal fuse mounted on the top left side of the element housing, it is round and has 2 wires coming to it. or, your breaker is partially tripped. go outside, and flip the dryer breaker off an on a few times, and then see if it heats. if you have any questions, let me know. tom www.applianceeducator.com/parts.htm:cool:
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
